Question about Tiger PDH-B30 Electric Kettle
I cleaned out my tiger kettle(PDH-B30u) and now no water comes out
Hello everybody,
I cleaned out my tiger and now it does not dispense the water. I can hear it try for a little bit but no water comes out. I think it might be clogged up. Anybody run into this yet?
0 characters
1 Points
No water coming out of hot side of dispenser, only cold
Like most coolers that have "hot" works of a "preheat" if you are not pumping out anything there is an obstruction that needs to be cleared.
Oct 23, 2013 | Sunbeam Hot Shot Hot Water Dispenser...
On my Zojirushi CD-LCC30 when I press the unlock and then dispense buttons I hear the pump "whirring" but nothing comes out. I have had my zoji for about 3 years and it has worked fine until now....
I called 1-800-733-6270 (taken from The rep was very helpful. She suggested that there was probably residue stuck in the tubes. She suggested that I use citric acid solution and put it through a cleaning cycle. After the cleaning cycle, do not pour out the water immediately. Instead, dispense the water through the Dispense button, to clear out the tubes. It worked. I had just gone through a cleaning cycle before this problem happened to me, and gotten rid of big chunks of "crud" (especially the build-up around the filter).
Nov 11, 2010 | Zojirushi CD-LCC30 Electric Kettle
Sunpentown SP-3000 Hot Water Pot Dispensing Button No Longer Work
Basically all eletric hot water pots are the same just like frig/stove.
pdf with wiring and parts.
Dec 22, 2009 | Sunpentown SP-3000 Electric Kettle
Where can I buy a rubber gasket or whole lid for Tiger PDH-B30U electric water boiler? Thanks.
try this site
Oct 04, 2009 | Tiger PDH-B30 Electric Kettle
How do I clean
Fill kettle until 3/4 full with 1 part vinegar and 2 parts water. Boil and allow to stand overnight.
Empty solution from kettle. Fill the kettle with clean water, bring to boil and discard water. Repeat and the kettle will be ready for use.
Or you can use a proprietary kettle descaler, which is available at most hardware stores.
May 16, 2009 | Breville SK550XL Electric Kettle
Magic mill hot water urn, 7.0 Qt
I replaced the cover once. With the second cover, I found if I put a teflon glove on the back left, the pump worked properly.
Mar 26, 2008 | Magic Mill 8.5Qt. Electric Hot Water Pot -...
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Tiger PDH-B30 Electric Kettle Logo
52 people viewed this question
Top Tiger Electric Kettles Experts
Are you a Tiger Electric Kettle Expert? Answer questions, earn points and help others
