Question about Panasonic TC-26LX20 26 in. HD-Ready LCD Television
Delay in picture coming on
When we turn the tv on, we get a grey screen (no picture) with good sound. Between 2 and 10 minutes later the picture appears.
5 Suggested Answers
SOURCE: Picture and audio delay from my plasma tv
no se como encontrar codigo de activacion de pantalla
Posted on Dec 13, 2010
SOURCE: no picture but has sound
we had the same problem and took it to be repaired and they said it was just a,loose connection
Posted on May 31, 2008
  • 1635 Answers
SOURCE: Viera TH-65PZ850U
Without investigation it is impossible to know what failed. There are a number of boards in that set where there is fairly high current used. It is possible that some components have failed.
The Panasonic service rep would service the set by swapping out the failed modules. If the set is an older model the modules may no longer be available. You can take the set in for an estimate to see if the parts are available, and to see if the set is worth to service.
Jerry G.
Posted on Jan 17, 2009
  • 11361 Answers
SOURCE: my television powers and lose picture 10-15 min later
You may have either failing 24vdc power supply due to bad DC filter caps, loose solder joints, or failing backlight inverter board. Those are the two areas you need to check out.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Please post back what you find.
Posted on Jul 24, 2010
  • 998 Answers
SOURCE: TX26LXD80 When switched on there
There is a problem with your t-con board it is the one that transfer image and get the signal from the logic board if this is faulty or not receiving signal to logic board it will produce gray and white screen try to check the 5volts dc supply and the 12volts supply if you are familiar with the electronic components and have proper equipment you can do it by your self but if not you can contact a technician to do it for you and save you from stress because this problem must be done in actual testing of the unit to check the real source of the trouble. Good day and best regards.
Posted on Aug 01, 2011
0 characters
1 Points
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Jul 01, 2015 | Sharp Flat Panel Televisions
How to fix a Sharp Aquos LC-40C32U Picture
Sony Plasma KDE 42xs955 has delay in of 5 to 10 minutes for picture to appear. Sound turns on immediately
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Oct 22, 2014 | Sony KDE-42XS955 42 in. Plasma HDTV
It pops and shuts off when I first turn it on. It finally stays on with sound and grey screen which changes colors. then the picture finally comes in about 20 minutes later
NEVER operate a set after it makes a loud pop. Only high voltage discharges can make such a sound. It is DANGEROUS to operate a set under those conditions. The chassis could be electrified or it could start a fire. Contact a qualified service technician.
Jan 09, 2010 | Westinghouse LTV-27w6 27 in. LCD HDTV
Soyo DYLT032D - grey box in corner, no main picture or sound
I am having the same problem. Does anyone know the solution?
Oct 29, 2009 | Soyo DYLT032D 32 in. LCD Television
Tv is on, after a few minutes it goes black and there is no sound. The indicator lamp is still green and stays solid the entire time. Without turning the TV off, in about a minute, you hear a small buzzing...
Someone else gave me the tip as I had the EXACT problem, but no buzzing. Unscrew the panel on the front bottom of the tv. Once that is off, there is another screw that opens a little panel. Unscrew the single screw with an allen wrench and pop out the bulb and casing. Mine was full of dust etc. Used an LCD cloth, but compressed air would do the same thing, put it back together and it works great!
Jun 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
TV with grey screen turns self off
This is an issue with the power supply. The capacitors used are faulty and you likely have to get a new board(about $400.00) or fix it yourself. LG's are quite east to disassemble.
You will be able to tell it is the power supply board due to the cable running from the plug to the board. It will look similar to this38376af.jpg
Next locate the bad capacitor, likely green and about the size of a quarter. You will be able to tell the bad capacitor by the bulge on the top.
At this point you can buy the new capacitor at a local t.v. repair shop for just a couple bucks or likely take the board to them and they should be able to fix it for 10-20 bucks. Unless you are decent with soldering I suggest taking the board in and having them replace the bad capacitor.
You will need a 2200µF 10V capacitor. I may suggest bumping to 2200µF 13-16V capacitor just so you don't have the same problem again.
Once the bad capacitor is replaced, replace the board and turn on the t.v. You should be good to go.
Feb 07, 2009 | LG 42LB1D 42 in. HD-Ready LCD TV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Toshiba regza 42" lcd sound but no video
Holding the power button down for 10 seconds fixed this problem on my Regza 47"
Jul 01, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Panasonic TC-26LX20 26 in. HD-Ready LCD Television Logo
56 people viewed this question
Top Panasonic Flat Panel Televisions Experts
charlie rodriguez
charlie rodriguez
Are you a Panasonic Flat Panel Television Expert? Answer questions, earn points and help others
