Question about Motorola Mobility RAZR V3xx Cellular Phone
Only button that works is the end button
The only button on my phone that works is the end button! i have tried turning it off and turning it back on a million times, leaving out the battery for a while and all that good stuf but nothing works
  • Anonymous Dec 28, 2007
    I have the same problem. Started yesterday. Still is not working
My old razr did something similar to this and they had to send me a new one. :( sorry.
Posted on Dec 31, 2007
The answer button and end call button not working, what could be th problem?
Hi there, I'm sorry to hear that you are having trouble with your Samsung Jet.
If the end call button works when turning the mobile on, then please try resetting your settings back to default by doing the following:
Menu - Settings - Reset Settings
If this does not work then please consider getting your mobile repaired by the manufacturer under warranty (if available).
May 03, 2011 | Samsung Jet S8000 Cell Phone
It won't turn on.
First try to remove the battery, to do that, you press the silver button that is at the lower end at the back and gently slide it down.
Remove the battery and fix it back,
There are 3 buttons on the front of the phone, the call button on the left, the cancel button in the middle and the end call button on the right.
Then hold down the end call button on the right side of the phone and it will come on.
if it does not, then the phone requires flashing.
take care
Jun 12, 2010 | LG Prada KE850 Cellular Phone
Samsung Blast Power Button No longer Works.
that happened to me after i dropped it in the toilet. if you pry up the keys around it aswell as the power key because they are all connected and push really hard on the silver thing it will turn on. then just push the keys back in place. trust me it works!
Jul 13, 2009 | Samsung Blast Cellular Phone
Turn off/end call?
This isn't really a solution but just my advice: regardless of whether it's a problem with the phone or the software, you'd have to either take it to a Verizon Wireless location to have them try and fix it (which is highly unlikely) or call up tech support. To me it sounds like some kind of software problem because it's highly unlikely that BOTH the inside & outside end/pwr buttons would be broken but ALL the other buttons on the phone work just fine. Most likely, as long as the phone hasn't been mishandled, ex.:dropped in water or on the ground, they will probably send you a "certified like new" phone in the same color/style as long as it's in stock, and then you will have to send back your phone. My one question is this: if you are not in a call but go into, say, your pictures folder or your contacts, and then push the end/pwr button, will it work then and take you back to the main screen or does it just completely not work at all in any fashion? Good luck!
Feb 25, 2009 | LG enV VX9900 Cellular Phone
End call button doesnt work--need help!!
u have to replace the carbon pad in phone
Feb 13, 2009 | LG Vu CU920 Cellular Phone
Wont turn off
First, take the battery out and put it back in to reset it. Then try again to see if you can manually turn it off.
This resets the phone and is the first step in troubleshooting.
Another thing I would do, is test to see if there is something wrong with the end button itself. With a flip phone, normally the end button is unneeded because you close it to hang up. Try ending a call using that button to see if it is a broken keypad issue.
I would also have the local store update the firmware, which should repair any files that may be corrupted, if that is the case.
Also, if the phone has any water damage (when you open the back of the phone, there will be a red dot instead of a white one), this can cause all sorts of crazy problems.
If none of the above solutions work, the only other way to power your phone off is just to remove the battery. You should be able to put the battery back in without the phone restarting, but if it does, just keep the battery out when you want the phone off.
Jan 21, 2008 | Motorola Mobility RAZR V3
Won't start on full battery
take ur batt out 4 30secs then put it bk in then try turn it on shoud work
Jan 14, 2008 | Samsung SGH-D600 Cellular Phone
Jabra bluetooth headset
how do I set up the phone to discover jabra vbt185z?
Dec 29, 2007 | Jabra BT350 Bluetooth Headset Headset
Wont turn on
take the battery out and put it back in. try replacing the battery
Oct 10, 2007 | Samsung UpStage SPH-m620 Cellular Phone
Motorola Mobility RAZR V3xx Cellular Phone Logo
59 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
