Question about Creative Labs Inspire T7900 Computer Speakers
POWER SUPPLY REQUIRED
Need new power supply for creative T7900 7.1 SPEAKER SYSTEM
  • gordofski Dec 16, 2007
    no good my friend the power supply that came with the speakers is now broken that is why I requested a new power supply
    I require a new power supply thank you
Hey friend i bought the t7900 while over sea's and needed a 110 option so i contacted creative for the power requirement and have been using a replacement laptop power supply with no problems
Posted on Sep 21, 2008
  • 56 Answers
You don't a new power supply for that speaker because they all have in the package with the power supply adapter ..all have to do is to plug the adapter to ac power outlet your speaker is gonna be function...
Posted on Dec 16, 2007
IS SONY SPEAKER VGP SP1 INPUT CONNECTION DIFFERENT FROM VGP SP2 SPEAKER CONNECTION
There may be many different power supplies that will work for your speaker system, but they must comply with the following:
1. The output voltage of the power supply should be correct as what the speaker system requires. (seems like 12 V in your case)
2. The specified maximum current output of the power supply should always be a higher value than the Amperage spec of the speaker system.
3. The output wires or pins of the plug on the power supply should correspond to the (+) and (-) on the power input of the speaker system.
A multimeter will come in handy to determine a power supply's output voltage and polarity.
Jan 25, 2016 | Sony Computers & Internet
Why my subwoofer has no power?
It could be a fuse blown in side the unit. it could be a bad power supply. it might be a power issue. make sure you have power connected properly and all connections are made correctly.
May 07, 2014 | Creative new labs speaker inspire...
SPK-VELO2 power supply unavailable
Go here: http://www.audio-unlimited.com/support and ask them. They have live chat to answer questions like this. If they can't supply you with a replacement you could ask them for the specs to guide you when selecting a supply. These include the current (in milliamps or amps required by the unit, and the size of power connector that will fit. Without this info no one could help you other than someone who is familiar with them.
Apr 13, 2013 | Cables Unlimited SPK-VELO2 Audio Unlimited...
What type of power supply is required for this speaker system? If available, how much can I expect to spend for the power supply? I have the speakers but no power supply.
Check the power-connector on the speaker for the rating:
* AC versus DC
* 4.5 versus 5 versus 9 versus 12 versus 18 volts
* 0.5 versus 1.0 versus 1.5 amps
* pole-negative-ring-positive versus pole-positive-ring-negative
Try the local "Thrift Stores", once you have the specifications. You may get the correct suppy for less than $5.
Apr 20, 2011 | Harman Kardon HK595 Computer Speakers
Red power light flashing
fault power supply unit, in older models, needs new power supply board, return to point of sale or manufacturers.
Dec 23, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
The power supply, LCP106830-0001 is bad. I need a schematic for Philips HTS-3555/37 and new poser supply to repair.
You won't get voltage if you completely disconnect the lcp106830 power supply from the board. The connection to the front panel is required and is used as feedback. I just repaired one and found one of the power diodes faulty.
Dec 20, 2010 | Philips HTS-3555 System
Dell PC was on at the time, and my little girl switched the PC off at the wall. Then switched it on and off a couple of times. Leaving it off. When pressing on/off button no power was in evidence as no...
Verify that the rocker switch on the back of the PC is in the correct position...check to make sure the minus sign is pressed down and if you have a power strip make sure it's in the on position as well. Then try powering it on. If it still won't power on, it's likely that you will need a new power supply.
Oct 25, 2010 | Dell HP-P2507FW Power Supply ** FREE...
Infinity home audio system subwoofer does not work.
Fixya is unable to source Infinity replacement parts.
Nov 18, 2017 | Infinity TSS-1100 System
Creative Labs Inspire T7900 Computer Speakers Logo
895 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
