Drum Install Cannon NP 4050 (full details) if possible
I have recently aquired and older cannon copier (NP 4050)
It ran awesome for months with no problems.
I had a local guy check it out (whom is no longer available) and his opinion was its time for a drum kit replacement..
I dont have the manual or schematic so I seeking direction..
I have brandnew drum in hand and ready to go....
Thank you in advance...
  • 1,326 Answers
Did you first clean the optics first. This will get the gray back ground or dark back ground gone. To remove the drum is not hard,but can be a dirty job. Fist take the 2 screws off the gray cover on the front of the drum. You may have to pull out the primary charge corona ass'y first. next disingage the developping ass'y gray lever on the right. It may be locked into place with a screw if so remove screw and turn the lever to the right. next look on the drum unit front plate for one screw near the hole where the primary was remove it and the drum should be lose. Make sure the trans port ass'y is in the down position. The drum should slide out towards you. Once it is out it is kind of self explained on how to get the drum apart. the only hard then is that the waste toner is inside the drum it self. It must be vacumed out or you will make a very big toner bomb in your room. Also, you will need a new drum blade as well. To reinstall the drum do the revese of removely. Good luck
Posted on Feb 11, 2008
How solves System error e225 in cannon mf 4200 series ufrii lt
If you wish to get some details; check the site linked here. Pull up older posts..
http://electro-medical.blogspot.com/
Jun 28, 2016 | Canon Office Equipment & Supplies
I have a cannon 6030 copier in my office that is not serviced anymore. I recently changed the toner, following all the directions from the manual. Now It only copies blank pages. It has no other error...
manually jam the paper & see if there is any images on your drum. if no image is there, problem will be in your primary charging. Corona wire may be broken repair it.
if there is image on your drum check if your transfer is ok. replace your transfer corona wire
Apr 14, 2011 | Canon NP 6035 Copier
E10 falt 4050 cannon machine
check main motor, motor control board, check if paper pick up unit is jammed or fixing is jammed any kind of moving part jam can cause error e10
Dec 26, 2010 | Canon NP 6050 Copier
Just aquired a Cannon IPF710 bought did not come
Try the Canon website they have drivers etc for free.
Mar 29, 2010 | Canon imagePROGRAF IPF710 Printer
My cannon np 6330 leaves a large black mark down the center of all my photocopies. how do i get ride of this mark?
This is most likely a drum problem. You need a new drum. Actually when a new drum is installed there are adjustments that need to be made in service mode. So you really need to have a tech do this for you.
Jun 10, 2009 | Canon imageRUNNER C6800 Copier
Copier ha a message that says replace toner drum.
It means that the internal drum unit is full of waste toner and that the drum is worn out too. The people at cannon made the drum unit to last when the waste toner internal compartment is full.
When you buy a new drum the instructions are in the box and very easy to install.
hope it helps
Mar 24, 2009 | Canon ImageRUNNER 1670F Copier
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
Cannon np 4050
The toner is not adding correctly into the developing assembly. 1) If toner hopper is overfilled, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) Sometimes the worm gear splits under normal use.
Jun 03, 2008 | Canon NP 6050 Copier
Canon np 4050 low fusing temperature
I am not 100 percent sure what is happening to your machine after it comes to ready, but I will offer some thoghts.
If it comes to ready and then goes back to a low heat situation. It very well could be the board if it doesnt maintain heat.
Now that being said, once a coiper comes to ready and reaches full heat, it will switch over to pulsating the heat roller, not staying on fully all the time. That is how fusers are designed. Full on until they reach operating temperature, then pulsating to maintain the rollers heat level.
If you are having a problem with the image not fusing to the paper, you may have an issue with the pressure roller not making good contact with the heat roller.
There may be a software setting that needs adjusted to increase the fuser operating temperature.
The flickering heat rod, once the machine reaches ready, seems appropriate.
If you want more of an idea, can you be more specific as to whether the machine is faulting out with an under heating situation, or is the image not fusing to the paper properly?
Dec 07, 2007 | Canon NP 6050 Copier
291 people viewed this question
k24674
Marvin
Marvin
