Question about HP PSC 1210v All-In-One InkJet Printer
Help my hp 1210 said i needed new color ink cartridge and i put a new one in then it said i needed a new balck one so i put one in too and the black is not showing up at all....this printer sucks someone help me please
  • 3 Answers
Re: help
Even if you are out of warentee, HP will cover their cartridges from 2 years from the manufacture date which is listed on the cartridge itself. If you go through more than 2 cartridges that are the same (NOT REFILLED, NOT REMANUFACTURED) then HP will replace it. There is a microchip in the cartridge itself which registers it's been in a printer before and if that has happened and it's remanufactured or refilled It goes "HEY I"VE BEEN USED" and rejects. - It's not the printer, it's probably the cartridge. Remember, that printer is almost 4 years old, things are bound to go wrong with hardware too (dried up ink in system clogging ink paths is common in old printers)
Posted on Mar 19, 2008
0 characters
3 Points
What ink is used in an hp q1660a printer?
Here is the Information that you are looking for.
Ref Link:
Inkjet print cartridge part numbers
Inkjet print cartridges Part numberHP 56 Black Inkjet Print Cartridge C6656A HP 57 Tri-color Inkjet Print Cartridge C6657A HP 28 Tri-color Inkjet Print Cartridge C8728A
Feb 18, 2013 | HP Q1660A PSC 1210 All-In-One Printer...
I cannot get my printer to print in only black and white. I have put new ink cartridges in, both color and black. I have selected "print in gray scale only" in the print options. But anything I...
Please take out the new cartridges and re-position them correctly i.e. color cartridge on the left and black cartridge on the right seating. Check that you hear a click sound when the cartridge is placed in the seating. Print a test page. Then switch off the printer for some time. Re start the printer and now carry out the gray scale printing.
Jul 19, 2011 | HP PSC 1210 All-In-One InkJet Printer
Hello. How do you clean the cartridge as it is a little dried up for printer HP PSC 1210 all in one printer?
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
The best solution for you is to buy some isopropyl alcohol from chemist, which is a great solvent for dried ink, and drop 8-10 drops into the ink nozzle, put it back in and try running a few prints then repeat the process. If it doesn't help, you will be better off buying new ink cartridges.
Jan 05, 2011 | HP PSC 1210 All-In-One InkJet Printer
What number is the ink cartridge
The ink cartridges for the 1200 Series can be either the high capacity HP 56 Black (C6656A) and HP 57 Tri-color (C6657A) or the low capacity HP 27 Black (C8727A) and HP 28 Tri-color (C8728A).
I hope this helps.
Nov 17, 2010 | HP PSC 1210 All-In-One InkJet Printer
New HP 56 cartridge prints green
hello, are you sure its green, since this is a black in cart, only thing i can think of is machine not printing black , and the color ink cartridge is contaminated, this would be due to the docking area for the cartridge, on the left side of machine, there are 2 black rubber cups that the ink cartridges move over to seal. sometimes these cups have residual ink, which will contaminate the new inks. clean these black cups, and replace inks
Sep 24, 2010 | HP PSC 1210 All-In-One InkJet Printer
After installing new original black & color HP ink catridges, still error "E" problem.. on a HP PSC 1210.
hi im josh in cebu phils.may i help you|? friend if your HP printer displays error after installing you orig.cartridges. the problem is in your software your software connections are already corrupting thats why he cant manage it to detect. all you have to do is re install your printer cd driver. but before installing the new one you need to uninstall or remove the old one first.thats all good luck hope i helped you
Feb 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
New Cartridge - Black showing no ink
u check ur head is working properly i think this main error of head where u insert balck vartrige if u have same printer then u have check replace the black cartrige find out it work properly then sure ur balck head is damage
Nov 04, 2008 | HP Business Inkjet 1000 - Printer - colour...
I have a hp psc 1210 all in one,it is playing up with print outs, is it possible for me to replace the print head on this model Rick
HP printers use cartridges that ARE the print head. On occasion, the cartridge could be defective...especially if they are the remanufactured type. Try replacing your cartridge with a new HP cartridge.
May 29, 2008 | HP Printers & Copiers
Balck ink not working
brother mfc-5440 ~ same exact issue on not printing the black AFTER purchase new cartridge (again!) ~ i should have checked here first.... NO MORE BROTHER printers in our future & will tell all our friends, too....
Mar 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP PSC 1210 - The Print Cartridge Detected is the Wrong Type * The following message is displayed on the computer: "The color [or black] print cartridge detected is the wrong type" * The Check Print Cartridge light is blinking, and the Check Paper light is off. This problem usually occurs after replacing a print cartridge. Soloution:
Aug 05, 2007 | HP PSC 1210v All-In-One InkJet Printer
HP PSC 1210v All-In-One InkJet Printer Logo
77 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
