Question about Sony PlayStation Portable (PSP) Console
Camcorder not record to card
Will not record to card. samsung 353 will record for 1sec then stop or freeze.
I formated the card. the pics work fine. but not the video. "read error!"
should I get a new card--this one seems ok because of the pics work.
anyway it is a piggyback card. that is it has an adapeter.
Could it be something else?? is this common??? should I return it????
oh thanks.
1. You posted a question about a Samsung camcorder in the Sony PSP section.
2. You say you're using a piggy-back card. That is likely the problem. It is fast enough to write picture / photo information to the card, but not fast enough to write video to the card. I suggest getting a proper (non-piggy-backed / non-adapter) card to work with the camcorder.
3. If you bought it recently then definitely return it to the store where you bought it. If possible open the new one at the store before you take it home to verify it's working before you leave the store.
Posted on Dec 19, 2007
My Samsung wb31F camera is showing file error I don't know what to do
make sure your sd card is in right,then if it doesnt work,put the card into your comp,download the pics,then format the card,then put it in your camera,if it works,move all your pics to it and put the card in the comp and d/l the rest of pics,now,format the card and put new batteries in camera and it should be fine
Apr 21, 2015 | Samsung Cameras
Need help working my camcorder/camera
In order to record, the camera needs to have a memory card installed. This particular camera needs an SD format card. If the camera does not have a card installed, the card is not properly formatted, or the card is full, you will not be able to record. Also, these cards have a write protect lock tab. Make sure that the tab is not in the lock position. The card should be formatted FAT32. If you can read the card on your computer, make sure it is not full and that the card is formatted FAT32. If you have another camcorder or camera that uses SD cards, you might want to try formatting the card, just to be sure.
Jul 16, 2012 | Mitsuba DV777 Camcorder
Camera will not record, just stops after one second, and photo's dont save. I have tried it with 2 cards that work in other cameras but won't do a thing,
Your internal memory is corrupted. Formatting your internal memory should solve this problem. Remove your memory card. Click on "my computer," click on "removable disk," click on "format." After formatting, reinsert the memory card and your camera should work fine.
Aug 24, 2011 | Kodak PLAYSPORT High Definition Camcorder
My polaroid dvf 130 camcorder won't connect to my computer.the software it came with says it doesnt need a driver since I have windows xp what should I do?
this is what i did, and it worked perfectly. go out and get a sd card * any gig u want* as soon as u put the sd card into the camera, FORMAT IT!!!!. do that before u do anything else. don't format it on ur pc or laptop. format it on the camera. if u do that it will work perfectly. i don't know why it wasn't in the manual to format sd card first. but if u try to take pics first, that will mess up the entire system and u will be assed out a sd card. it took me 3 sd cards to figure this out. the cards worked fine but not in the camera. then i formatted it on the camera first and it works fine. the other sd cards i use for other things, i won't discard them but they won't work in the cam. but remember again GET NEW SD CARD AND FORMAT THE CARD IN THE CAMERA FIRST.
Jun 29, 2010 | Polaroid DVF130 Camcorder
This camcorder does not record video; it won't format memory card
do you get any kind of error code?what type of memory stick are you using?how big is the ms capacity?may need to try using a diff ms or try using ms with diff devices.if diff ms works fine.may need to format ms using computer first (using card reader if available) and camcorder last.may need to reset camcorder (make sure cam is on when you press the reset button.hope this works.thanks :)
Mar 12, 2010 | Sony Handycam HDR-CX12 Flash Media...
Memory Card Problems
According to the samsung website " Samsung camcorders manufactured in 2004 and later can be used with memory sticks up to 1GB. Anything over 1GB is not guaranteed to work. "
I have the same problem. Video works fine on my 256MB card but not on my 4GB or 8GB cards. It would be nice to know if anyone has success with a particular card >1GB.
Jun 03, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Sony handycam not recognizing memory stick
i think the 108 will only put pics on card- may not show card unless in camera mode-put in camera mode w/no disc and see if it shows how many avail pics-i don't think 108 records video on card
May 21, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Will not record to card- read error!!
TRY A SMALLER CARD SEE IF THIS HELPS.. THIS MODEL DONT ACCEPT ALOT OF MEMORY
Dec 14, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung scd103 camcorder memory card
From the manual:
“Memory Stick PRO” can not be used with the SCD103 MODEL.
You MUST use only a memory stick, not the PRO
Nov 18, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony PlayStation Portable (PSP) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
