FixYa.com
Tags:
Sony KDF-E50A10 50 in. HDTV LCD Television
TURNS ITSELF OF AND THEN BACK ON AFTER ABOUT 45... (by 9 users)
posted by crail on Dec 14, 2007
I HAVE A PROBLEM WITH MY SONY KDF-E50A10 TURNING IT SELF OFF AND THEN BACK ON AFTER APPROX. 45 FLASHS OF THE STANDBY LIGHT,IT DOES THIS RANDOMLY.I HAVE ATTEMPTED TO RESET IT BY UINPLUGING IT FROM THE WALL FOR 5 MIN. AND THIS DID NOTHING...PURCHASED THE SET IN 12/05 SO IT IS ALREADY OUT OF WARRANTY AND THE SONY WEB SITE SAYS THAT MINE IS NOT ONE FOR THE SOFTWARE UPDATE...CAN YOU HELP !!!!!THANKS!!!!!
Comment by crail, posted on Feb 07, 2008
2 years old!!!!
what would a lamp run me?????
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
8 Other Users Have The Same Problem
Comment by BnrMan213, posted on Jul 30, 2008
I try to turn my tv on and it doesn't come on. It just cycles the green power light then to red then it shuts off. The Tv was manufactured in December of 2005.
Comment by Guest, posted on Jun 03, 2008
I had the exact same problem with the exact same tv. My tv was about 18 months old, but on all of the time. I had a tech scheduled to look at and stumbled on a website with a bunch of tv repair men answering questions. they suggested my lamp was on its last leg. I replaced the lamp and have not had a problem since with the tv turning on and off by itself. Unfortunately, I now have a large blue blob taking over my screen and sony is acting like they never heard of the problem before. Sony blows!
Comment by oski65, posted on May 28, 2008
TV won't go on. Just see a black screen. The green power light will blink for a minute or two and then turn to red and continue blinking. Tried unplugging for 5 minutes to reset without success.
Comment by saranaff, posted on May 18, 2008
Our tv also does this. It also has a blue streak in the upper right hand corner. We bought it May 24, 2006. We purchased an extended warranty so I wonder if it will cover this problem.
Comment by BarbH918, posted on May 03, 2008
I have the same problem - mine doesn't need the update either. Just started today. I went through the live chat support and after I reset it from the wall I was told to call service.
Purchased January '06.
Best Solution
posted on Feb 06, 2008
Helpful (85)
HDTV GURU
Rank:Guru Guru
Rating: 86%, 90 votes
How old is the set? The lamp maybe going bad already...IF not that, its the ballast power supply...GURU JAY
Comment by HDTV GURU, posted on Feb 07, 2008
Have you tried replacing the lamp? I may have one for that unit... Let me know what the part # is...Should be something like A-1085-447-A or XL-2200. Keep me posted and well have u up and running in no time. Have a good one.. GURU JAY
Lamps cost around $200.00 plus S&H. Let me know if you have the lamp stated above. I have that one in stock. GURU JAY
Rating Locked! (?) crail has rated this solution as Helpful
Solution #2
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had the same problem, it would take the tech two weeks to get to me. So here is what i did, and the problem seams to be fixed. I took out the lamp and dusted the lamp area. There was alot of dust. I then replaced the lamp. I have not had a problem since.
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on Mar 10, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Im looking for a KDF-E50a10 for parts. I need the screens.
727-485-5163
Can you Help with these Flat Panel Televisions problems?
problem with my Sony Bravia 50
my t.v has developed a problem... Answer This...
Blue colors appear greenish in...
Blue colors appear greenish in... Answer This...
Standby mode
When you turn the tv on it goes... Answer This...
No Pricture just a flashing...
When I turn the TV on, I get no... Answer This...
Sony KDF-E50A10
When I turn on the TV, I have... Answer This...
8 Other Users Have The Same Problem - Continued
Comment by geegee21, posted on Jan 10, 2008
I have the exact problem. Turns itself off and then back on again after 45 flashes of the standby light.
Comment by Guest, posted on Jan 07, 2008
Same problem here. Turns itself off then on, over and over again. So far I've found no cause or resolution. I'm about to pitch this piece of junk out in the street.
Comment by Guest, posted on Dec 14, 2007
App 3 days ago I started having the same problem. Exactly 45 flashes as you say. My TV was needing the upgrade. I had that done but the problem still exists.
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
