Question about Samsung SC-D353 Mini DV Digital Camcorder
Will not record to card- read error!!
Hi --the pics to card works fine--so I suppose the card is OK>
I formatted it as well-- it is a dual card with a pro inserted into it.
Anyway, it records for 1 sec. and stops. I have to shut off the camera cause the record/play button will not stop the record. the vidieo will not read. 0, bits.
everything else seem great. ugh
  • formula89383 Feb 14, 2008
    i have the same cam and the same problem. im using a new 2gig sandisk duo with the adapter. it acts like it formats the card but does the same thing yours is doing.
    TIA for any help
  • 73 Answers
Posted on Mar 02, 2008
A) Please don't shout.
B) What method are you using to transfer the images to your computer ?
Jan 05, 2017 | Cameras
My Samsung wb31F camera is showing file error I don't know what to do
make sure your sd card is in right,then if it doesnt work,put the card into your comp,download the pics,then format the card,then put it in your camera,if it works,move all your pics to it and put the card in the comp and d/l the rest of pics,now,format the card and put new batteries in camera and it should be fine
Apr 21, 2015 | Samsung Cameras
Panasonic HVX 200a can't get video only still pics just bought need help
You can us SD and SDHC cards in the camera. But it is not supposed to record stills. It should record Video or Audio,
The manual is still online. The camera is to complex, to start shooting, without the correct setup. It needs to know where it should write the data, on the tape or on the card and that is not the only thing you need to setup correct.
Oct 21, 2014 | Cameras
Memory card error?
Hi, Check if other memory card is working on your camera. This is one way of checking if your memory card if still working or there is an issue wither the camera. Formatting Memory card **you should always format a new memory card or one from which you wish to erase all images and other data. ** Please note that formatting a memory card erases all data, including protected images and other file types. 1. (Set up) Menu [Format]
2. Select [OK] and press FUNC SET button.
Low Level format, recommended by cannon
Select the [Low Level Format] when you think that the recording/reading speed of a memory card has dropped. A low level format may require 2 to 3 minutes with some memory cards.
Apr 12, 2010 | Canon PowerShot A610 Digital Camera
Camera will not read disc, I have formated disk and have transfered pictures onto disc. Disc is working and can view pictures from disc on my computer. when I put disc in camera I keep get message to...
If you have moved pics from your computer to the card and then inserted the card into your camera, the card is now formatted to the computer, not the camera. You're supposed to format the card in the camera.
Apr 03, 2010 | Kodak EasyShare P850 Digital Camera
Fugi S5000 2gb xd M+ Computer says it's not formated
Yes, it would appear that you solved your own problem. The Fuji S5000 apparently only takes the max of 512 mb card. I own a newer Fuji S700 and it works fine with a 2 gb SD card, but I haven't tried anything bigger. Your best bet is to see if you can exchange those 2 gig cards for 512 mb cards at the store where you purchased them, and then try the 512's to see if your pc will read the pics. Explain to the store what the problem is and they should allow you to make the exchange.
Aug 06, 2009 | Fuji FinePix S5000 Digital Camera
I just bought a Z1285. I put SD memory cards with pics and videos made with my Z730 in it and i can view pics ok but when i try to view videos screen reads"unrecognized file format" Whats up with this
Hi this is a simple one!
The Kodak Z730 records movies at the following resolution and frame rates 640 x 480, 12 fps, 320 x 240, 20 fps while the Z1285 records movies at the following resolution and frame rates 1280 x 720, 640 x 480, 320 x 240, 30 fps therefore you cannot view the Z730 movies on the Z1285 and vice versa.
Jul 10, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Camcorder not record to card
1. You posted a question about a Samsung camcorder in the Sony PSP section.
2. You say you're using a piggy-back card. That is likely the problem. It is fast enough to write picture / photo information to the card, but not fast enough to write video to the card. I suggest getting a proper (non-piggy-backed / non-adapter) card to work with the camcorder.
3. If you bought it recently then definitely return it to the store where you bought it. If possible open the new one at the store before you take it home to verify it's working before you leave the store.
Dec 14, 2007 | Sony PlayStation Portable (PSP) Console
Samsung SC-D353 Mini DV Digital Camcorder Logo
133 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
