i am trying to find an alternative to solve this problem, and i am hoping the solution would be not changing the whole thing, but hardware or software issues that maybe some of you encountered also from the past.. anyhow thank you so much for your solution, i will make it as my last option.. believe me i will.. thanx.. i am trying to find an alternative to solve this problem, and i am hoping the solution would be not changing the whole thing, but hardware or software issues that maybe some of you encountered also from the past.. anyhow thank you so much for your solution, i will make it as my last option.. believe me i will.. thanx..
You can't post conmments that contain an email address.
Dear The problem is main board inside monitor which is needed to be
changed with new one. So I suggest you to take monitor in nearest
samsung's service center. Best regards
Hook up a different monitor and set resolution to no higher than 1024 x 768. Samsung monitor will then work fine. It appears that something fails in the monitor and it will no longer support anything higher than this.
change windows resolution and refresh rate to 1024 X768 and 60 Hz. start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
reinstall the display drivers in safe mode this you can do by pressing F8 and in safe mode, you can also try restoring the machine to previous state Good Luck
Dear The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor in nearest samsung's service center. Best regards
