H
I have managed to find a description of this error here: Error Codes Toshiba Studio 4511 Code F090
which says: Description:- SRAM abnormality on the SYS board
Unfortunately the page doesn't give a remedy for this error as it normally does, but you can download a pdf format service manual from this site by clicking on the link near the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
3511 and 4511 color machines will be obsolete at the end of this month. Advise you call your local Toshiba dealer and talk to them about a trade in upgrade.
That code error meaning that you have a problem with HHD 1st you reboot your machine with push 0+8 than 690 start 2 set(interrupt). If it don't wok you mast replace your HHD with a new one from Toshiba.
f100 is a hard drive formatting error [F100] HDD format error (1) Check if the HDD is mounted. (2) Check if the specified HDD is mounted. (3) Check if the connector pins of the HDD are bent. (4) Check if the connectors CN116, CN132 on the SYS board is disconnected. (5) Replace the harness. (6) Format the HDD. (Key in "2" at 08-690.) (7) Replace the HDD. (8) Replace the SYS board. step 6 is turning the copier on while holding 0 and 8 til it beeps type 690 and hit start, this will format your hard drive, more than likely it is bad physically but you may get lucky
