Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
Problem for Western Digital 250GB MyBook External USB 2.0 250 GB Hard...
I've hooked it up to a USB hub and Windows says
By wigglewart on Sep 21, 2009
I've hooked it up to a USB hub and Windows says the USB device is unknown
Clarification Request
Posted by anonpi on Sep 22, 2009
Is this a Windows OS prior to windows XP?
Posted by paranz on Sep 21, 2009
what OS version of Windowsare you running? anything earlier than XP might not pick up the plug and play driver, therefore you need to have a driver disk to install first. ie Windows 98 , ME and possibly Windows 2000 all will need a driver file preinstalled before plugging it in.
Best Solution
posted on Oct 04, 2009
Very Helpful)
bob_computer
Rank: Guru  Western Digital Computer Accessories  Expert
Rating: 87%, 1224 votes
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Western Digital 250GB MyBook
Questions and Unsolved Problems for Western Digital 250GB MyBook
Do you recommend Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive?
Answer
Answer
MAC TimeMachine no longer sees WD passport 250GB''The storage location for TimeMachine Backups can't... (More)
Answer
i have a western digital 250gig hard drive that i need to reformat and i keep getting a box that... (More)
Answer
My portable hard disk shows an error msg windows explorer has stopped working while opening
Answer
I have a Mybook Studio connected to my iMac and linked to Time Macine for back up. I have just... (More)
Answer
i can see the disk in my computer i have a lot of files on the drive but it does not allow me to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Western Digital 250GB MyBook...:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
