Mower ran fine a couple days ago. Went to start yesterday - engine turned over, backfired, and gas spewed out the front of the mower. Won't start.
Remove the plug, pull the rope several times. Wait about 30 minutes. Put the plug back in. Try again.
Choke off? Use sparingly if at all. If you have a primer button, only press it 5 or 6 times.
Is your plug in good contition? It may need a replacement. Make sure you get the correct plug.
Let me know how this works out.
a
Is this a pushmower or a riding mower? if its a riding mower sounds like the needle in your carb is allowing fuel into your crankcase check your oil level.
