Question about Sony DCR-HC19E Mini DV Digital Camcorder
Cannot close camera
When I put the tape in it won't close, pushing the cartridge rack in position is not locking in
  • mannie51 Jan 28, 2008
    Thanks for your help. I still have the problem but now I know the solution. I have a missing spring. This spring is attached on the side of the holder where the tape is put. This spring pulls a small lever when the tape is pushed in causing it to lock. All this is not happening because the spring is not there. I will try to buy one from a local electronics shop.
    Thanks
    Problem Solver:
  • 4 Answers
Maybe u dont put it in right position? It has happened to me before too.. try take the tape out and put in again, and press until u hear a klick sound..
Posted on Jan 27, 2008
    Problem Solver:
  • 5 Answers
Hi, I have the Canon Pixma MX310 and I tried to replace the ink cartridge but I messed i up and I still don't know how to replace it... I think it's error 5100 or something because it says it on...
Installing ink cartridges:
Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.Note: - Do not attempt to reattach the protective tape once you have removed it.do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
  1. *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  2. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)Confirm that the ink cartridges are installed properly.OR
  3. <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
  5. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
Sep 24, 2011 | Canon PIXMA MX310 All-In-One Printer
Sony camcorder
The tape is locked by a pin on the cornerside, check the locking hole on tap.
Jul 18, 2008 | Sony DCRHC90 Digital Camcorder Extra Gear...
How do i reset ink cartridge cl511for my canon ip2700
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
Sep 20, 2011 | Canon Office Equipment & Supplies
Impossible to insert the cartridge in a printer always shows that it is not a good loaded
  1. After confirming that the printer is powered on, open the scanning unit (printer cover).The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support <1> is fixed into position, release your hands.
    *MP470 shown
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Nov 30, 2010 | Canon PIXMA® MP210 Printer
How do I load the ink cartridges into the Canon Pixma printer MX320?
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
3. FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
(E) Closed correctly
(F) Not closed correctly (the cover is tilted)
6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
Oct 05, 2010 | Canon Office Equipment & Supplies
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
I m having problems installing the ink cartridges and sggestions?
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
Nov 03, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon ZR85 camcorder won't turn on
Steps for removing the tape from a totally dead ZR85:
1. Turn camera upside down.
2. Move "Open/Eject" button to full right position (toward lens).
3. Manually push tape door open.
4. On the metal surface that sits between you and the tape, there is a very small screw. There is probably a yellow sticker next to the screw that says "Do not press on this part". With a small jewelry phillips screwdriver, remove that screw.
5. Push the metal plate (with tape) in the direction ofr the door and lift slightly. The metal assembly holding the tape comes loose, exposing the top of the tape.
6. Pull the tape upwards (out of the camera). At this point, the tape will still be engaged in the play heads. With the cartridge out far enough to see the heads, reach in with your jewelry screw driver and carefully lift the tape over the heads, and free from the camera.
7. Use the eraser on the end of a pencil to wind your tape back into the cartridge.
8. When re-assembling the mechanism in the camera, there are two curved slots on both sides of the piece you took loose. You'll need to thread these onto two posts inside before you place the top back in position and put the screw back in.
May 10, 2008 | Canon ZR85 Mini DV Digital Camcorder
Mp 460 tryin to insert ink for the 1st time
Your post is in the wrong place. I almost got you the wrong directions. LOL
Issue: How do I install the ink cartridge(s)?
Solution: Installing / removing ink cartridges MP160 / MP180 / MP460
Installing / Removing Ink Cartridges To print normally, install or remove ink cartridges in an orderly procedure. Installing ink cartridges:
Nov 12, 2007 | Brother HL-2040 Laser Printer
Sony DCR-HC19E Mini DV Digital Camcorder Logo
48 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
