Question about HP OfficeJet Pro K5400dn Photo Printer
Bad printout Printer runs well and then black printout starts fading out like it is running out of ink. Changing the print head and changing the ink cartridge does not help. Cleaning the print heads does not help. Aligning does not help. I purchased one of these printers in October and one this week. Both have the same problem. HP mentioned a "MAC" software problem, but I am using a Compaq PC.
  • greveland Dec 14, 2007
    Just started. First one worked for more than a month before faulting, second worked for a week before faulting. I installed the software from the cd shipped with the equipment.
  • greveland Dec 15, 2007
    Removed and reinstalled the software. The printheads are easily cleanable on this model as the whole printheads pop out and the permanent contacts are easy to get to. But, on the original printer, after I let it setfor a number of days, the diagnostic printouts did fine at first, and then went back to the black disappearing. The "alignment" diagnostic now shows no black at all and anothe diagnostic comes out with just three large red Ns.
  • 4,102 Answers
Hi have you installed the software that came with the printer.
Also has this problem just started or has it been like it since buying let me know ok thanks
Posted on Dec 14, 2007
  • paul proctor Dec 14, 2007
    If they was working fine at first then the problem wont be a software one.
    Has anybody had acess to your computer and acidently changed the settings on the printer or even made it so your isnt the printer selected.
    First thing i would try is delete the software you installed completley remove the software for it then reinstall it from scract this would eliminate software problem.
    If after doing this it still dont work i would check the leads are ok and not kinked or anything like that and are you 100% sure the print heads are clean and not blocked as this is often the case.
    try reinstalling the software this will eliminate any corrupt data.
    Let me know how you get on ok
  • paul proctor Dec 15, 2007
    Hi it sounds like you might need to get it realigned then this isnt something you can do yourself as you wouldnt be able to get it perfect.
    It just seems a bit stranged that this has happened to two printers witch is usually software problem if it is same problem on another printer.
    maybe its common fault with that model.
    The best thing to do is take to repair shop and get it realigned this is the only sollution that matches your problem if you are sure the heads are perfectly clean then that is the only option let me know what you want to do ok
How to repair no print of pos printer epson tm t88iv?
did you try the basics cleaning heads , running test setup for the dot matrix printout out , changing ink sometimes ne packages sold are garbage.
Sep 05, 2014 | Epson Tm-t88iv Black Thermal Receipt...
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
I have a ip4200 and when printing in black it is faded and stripe
The print head is clogged.Make sure black ink cartridge have ink and then try unclogging with cleaning tests in maintenance mode.If not help try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap
water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If
this not help you need to replace the print head.
Nov 20, 2009 | Canon Office Equipment & Supplies
It prints, but not visible, i change ink on all of them and is the same only in black, all other its fine on my MFC-420cn.
You have a dirty ir clogged print head. You can sometimes get it to work again by running a lot of cleaning cycles. 10-30 cycles is sometimes how many it can take. Unfortunately sometimes that won;t work so you have to hit it with a bigger hammer in this case you can clean the print head using q-tips or lint free paper towel and vinegar. The vinegar dissolves dried ink. If this works (it usually does the trick) the printer can work as well as the first day you got it.
Remove the ink cartridges. Then to clean it you need to wet the swab or the towel and gently rub the print head where it touches the paper. You will see a little ink then a lot then it will fade out as you get the head clean. Generally after it starts fading out that means you have most of the dried ink cleaned off. Replace the ink carts and then run a cleaning cycle and you should have your printer working again.
If none of these work then it may be too badly clogged and you should just consider getting a new printer as the print head is worth about what a new printer will cost.
Nov 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Problem with printing in black writing not clear and very faded.
It sounds like you need to run a printhead cleaning. The print head is what you put the ink cartridges into, it's responsible for placing ink directly to the page. If the some of the nozzles are clogged up, it can give you bad print quality. Without knowing the exact model of your printer, I can't tell you exactly where to find the menus needed to run the cleaning. Sometimes you can do this via the "maintenance" tab in the printers properties. If you need any further assistance, feel free to let me know.
Jul 30, 2009 | Brother Office Equipment & Supplies
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
My black ink will not print. If I change the colour, it prints find. It is a new cartridge.
First you need to ensure that this is not a driver problem, by reinstalling drivers and testing the printer on a different computer.
Also ensure that ink cartridges are OK, try replacement inks.
If the problem is not a software problem, and the printer is recognised by computer, and the printout is coming as a blank or faded page, then you usually have a faulty or clogged printhead.
Try first performing print head cleaning procedure from printer tools, that may not fix the problem, but do the cleaning a couple of times, just in case.
If the print head is clogged, that can be fixed soaking the print head in isopropyl alcohol overnight.
If still no luck, then the printhead must be replaced, here is the part: Canon MULTI-PASS F-80 Print Head $61.00
Apr 26, 2009 | Canon MultiPASS F80 All-In-One InkJet...
HP OfficeJet Pro K5400dn Photo Printer Logo
82 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
