Mitsubishi WS55513 tv
Tv will not come on. green light on front panel blinks constantly even after tv has been unplugged for a while and having did the reset on the front of the tv
  • djk328 May 02, 2008
    i have the same tv and same exact problem and the warranty expired.Can you help with some advice
    President:
  • 4,402 Answers
Capacitor problem.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
Posted on Dec 14, 2007
Green blinking light on Mitsubishi DLP 52825
Hello, unplug the tv and check the lamp to see if it is broken inside. here's a link on how to replace the lamp.....tks.... https://www.youtube.com/watch?v=3bQ0wut_pWg
Jan 26, 2015 | Mitsubishi Televison & Video
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 55" rear projection TV, wouldn't turn off
um . that model doesn't have a reset button . but if no lights on front of the set even blink when you press the power button on the front or on the remote .then suspect front panel buttons ,with that model.
Sep 29, 2009 | Mitsubishi WS-55819 55" Rear Projection...
The timer light green blinking all the time
You most likely have some bad capacitors on the dm board, unfortunately the board is not available for this set, the complete chassis has to be sent in to Mitsubishi to be rebuilt.
Sep 08, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-55511 Problem TV out - Getting only continously blinking green light on the front-panel
I had the same problem with the blinking light on the front of the TV and it would not power up. I read all the problems everyone was having and thought I was going to face a huge repair bill. The service guy came out, pulled off the front panel where the speakers are and disconnected the circuit for the front display panel. 3 1/2 minutes in my house, $90 service call. Apparently, when you give the TV too many commands at once, it's safety feature is to"shut down and lock up". He mentioned also that sometimes when these sets get to be about 4-5 years old, the wires in front can "leak" causing a shortage and then locking up the TV. I keep the circuit unplugged and operate the TV solely by the remote. Give it a try, what can it hurt!! Hope this helps.
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Televison & Video Logo
198 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
