Question about Advueu Technology AMW-F196B
AMW-F199B intermittent turn on
When I first turn my monitor on it comes on for about 3 sec. then goes off. I wait 3 sec then turn it on again. It comes on for 3 sec then goes off. By repeating this cycle for 50-100 pushes of the button, I can get it to come on and stay on until I turn the PC off. It works this way with 3 different PC's, so I think it's not a PC or software problem, but in the monitor. Any help? If not, can you direct me to a site that might tell me how to take the cover off so I can look at the on button? I'm about to take my axe to the cover.
  • jdahlberg Dec 29, 2007
    I have the same problem with my AMW F199B monitor. When I first turn my computer on, I have to push the power button on the monitor to turn the screen on. Initially, the screen turns on, but it shuts down after several seconds. I hit the power button on the monitor (turn the screen off and on) and it seems to reset the monitor, but only for a few seconds. After I repeat this five or six times the monitor stays on for the duration of my computer usage. If I leave my computer idle for a time and allow the screen to go to "black," I have to repeat the process of turning the monitor off and on several times before it works normally again.
  • robertyy Dec 29, 2008
    the website www.advueu.com doesn't work.
    use PROMEDIALCD.COM
    tel. 888 622 5005
    company is promedia (adveue is a branch.)
I had same problem. I found that there were 2 capacitors on the power supply which were bulging which means that they were faulty. I replaced them and unit worked ok. The values for the capacitors were 680 uf / 16V. If anyone wants any more detailed information, let me know.
Posted on Jan 08, 2008
Where can you get capacitors for amw f199b
Posted on Apr 16, 2008
I was wondering if I could get the photographs and diagram as suggested earlier. I think I have the same problem.
Posted on Jan 16, 2008
Problem is most likely the power supply inside the unit. I had same problem. I removed the back panel and found 2 capacitors on the power supply bulging. After replacing the capacitors, the unit worked ok. If anyone is interested in more detail and pics, let me know.
I still havent got an answer 2 how 2 fix my monitor problems
Posted on Jan 02, 2008
The web site is http://www.advueu.com. I asked their support about the problem. They were polite, but of no help. They won't tel how to remove the cover for liability reasons. I'm afraid that your experience is not reassuring. I will post here if I find an answer.
Posted on Dec 17, 2007
My monitor did this as well for several months. I don't turn my PC off. Mine was being triggered by windows putting the display to "sleep" in power save. After several months of the same porblem you have, it is now non working all together. It powers on (sort of ), the power LED flashes green (not steady like normal), however the monitor stays blank. I found the website for AMW a while back, but can't seem to find it in google now. Good luck with yer problem, hopefully you can get it fixed before its down for good. Let me know what you find out. I'm desperate to get mine working
Posted on Dec 16, 2007
When I plug the monitor it won't stay on. Why?
1. CRT or LCD?
2. Do you have an image of any kind for that 45 sec.?
When it drops out after 45 sec, do you have any strange behavior as you look at the screen (colors, blinking, lines, squiggles, noises, smells)?
3. When failing, does the power drop out (ON light goes OFF)?
How long do you need to wait until you can turn it ON again?
4. What is the status of your screen saver/power saver? 45 sec seems pretty short but it's still possible.
5. What does the manufacturer's website have to say about this problem? What do other users have to say when you search for your model?
I know these are just more questions but your question is too generic to offer specific comments that might be more useful.
Apr 12, 2013 | Computers & Internet
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Acer monitor swtiches itseolf off in i9n about 15
After much ado and waiting for tech support from Acer, remembered that some years ago something similar happened with a printer so I downloaded a new driver from acer for the monitor onto another computer, copied it to cd and then with much fiddling installed this on the acer, as it was installing monitor started to flicker and finally lit up again normally. Now working perfectly! When tech support phones, will tell them!!!!!!
Nov 20, 2009 | ViewSonic VX2235wm LCD Monitor
AMW 199B monitor takes forever to come on
My AMW 199B shuts down.On button shows no light.If push on button nothing happens.So I unplug it and it will come and stay on for a long time,(last time a day), then all of a sudden it will shut down
Aug 04, 2009 | Advueu Technology AMW-F196B
My F199B seems to have a bad display after
You need to download & install the Windows 7 druvers for your graphics card. Once this is done your display should be fine. Hope this helps.
Jun 26, 2009 | Advueu Technology AMW-F196B
Monitor intermittently goes dark and will not come on
check you monitor cable or replce it. tahnk you..
Feb 05, 2009 | Computers & Internet
Blank screen with intermittent operation
you have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Dec 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
AMW F199B 19 Inch LCD Monitor - No Red
I just changed PC and and I have a "AMW F199B" monitor that will not produce sounds now. I do not have any of the original software for the monitor. What do I do?
Thanks
Jun 14, 2008 | Advueu Technology AMW-F196B
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Advueu Technology AMW-F196B Logo
1,227 people viewed this question
Top Advueu Technology Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Advueu Technology Computer and Internet Expert? Answer questions, earn points and help others
