Question about Dymo LabelWriter 400 Turbo Thermal Printer
Dymo 400 Turbo shows offlline
In the middle of the day it shows offline and have to unplug the USB connector and plug it back in. It prints fine up till that point. Powering off doesn't help.
  • Anonymous Apr 19, 2009
    Unplugging the USB cable and reinserting brings the printer back online. However, upon a reboot of the PC, the DYMO printer will again show offline.
Check your cable
Posted on Dec 17, 2007
Printer offline
You did not specify if printer was formerly working, the model # of the printer, or what version of Windows you are using. All this information is needed for successful troubleshooting. However, the below is general resolution for your problem:
"Offline" means your computer cannot "see" the printer as connected and powered on.
In order of things to try:
1. Turn printer OFF. Unplug USB cord from printer (or other end from computer). Wait at least 30 seconds. Plug USB cord back in. Turn printer back on. Does it still show as "offline" under Start --> Devices & Printers?
2. Try replacing the USB cord (yes, they can and do go bad).
3. Turn printer off. Unplug USB cord.
Under Windows Start --> Printers and Devices:
RIGHT click the Konica printer icon. Select "uninstall" (or "remove device") and follow through until printer is successfully UNinstalled. If there is other Konica software installed, remove it also (via Start --> Control Panel --> Add/Remove Programs -or- Programs & Features).
4. Reboot your computer. Follow manufacturer printer installation procedure, step-by-step (consult mfr website if you do not have a printed installation manual). Do not plug in USB cord or turn on printer until instructed to do so.
If all else fails:
Ignore any manufacturer installation instructions.
Do # 3 only above.
Reboot computer.
Plug in printer and connect it to computer.
Let Windows try to automatically install it (in most cases, Windows can install the "basic" print drivers, which are smaller and sometimes more stable than the fancy drivers and excess software the manufacturer wants you to install).
If still no go, you probably have a dying or dead printer. Consult manufacturer website for help.
Mar 07, 2014 | Konica Minolta Office Equipment & Supplies
DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
First of all, on Dymos you need to use original Dymo roll,.
Dymo rolls have a tag at the back, non original ones does not have it.
Before reinstalling driver you also need to run the dymo uninstaller utility that you find at Dymo website.
I will post the links for download.
Oct 03, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
I have A Canon MX410 printer and is showing message offline and I have unplugged and plugged the printer. I have a Mac Mini and it worked fine for awhile. What to do??? Thanks Rick
Is the Pixma connected to a wireless router (or connected by USB or ethernet cable)? It could be that the router connection failed. Try restarting the router, or repeat wireless connection on the Pixma.
Feb 04, 2018 | Canon Pixma MX410 All-In-One Printer
Keeps showing offline even though I put in new cartridges and it cleans. When I test print, I have to do it manually and the paper comes out blank. When I check the ink status for some reason it shows...
First unplug your printer from the computer then uninstall you installed driver . After that plug it to the computer and install driver again. Then restrat your computer after successfully instalation. If still now ggive the problem then install driver from the below link and install it.
http://download.cnet.com/Brother-MFC-240C-USB/3000-2110_4-99329.html
hopefully it will be work. Other wise go to the servicing center.
May 04, 2011 | Computers & Internet
Canon MP24o computer thinks it is offline, but it is hooked up and on etc.
Possible solutions:
* Try restarting your PC.
* Hook-up the USB connector to the original USB port... If unplugged.
* When you print choose the latest printer detected... copy 1 or copy 2
* Delete the printer and re-plug the USB port.
* Defective USB cable, try other cables.
Mar 26, 2011 | Canon PIXMA MP240 All-In-One InkJet...
My Dell 1700n Printer keeps showing up as offline. I have a Dell Optiplex GX520 PC. My printer has been working fine, I moved the printer to a new PC temporarily and then moved it back to my PC and now...
hi
i suggest you reinstall the drivers on the computer(s) which will use the Dell 1700n printer.
let me know if this helps
if you need the drivers go to this link all you have to do is select the operating system (go to My Computer, right click and properties, will give you the OS)
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&ServiceTag=&SystemID=PRN_LSR_1700N&os=WW1&osl=en&catid=&impid=
Nov 03, 2010 | Dell 1700n Laser Printer
Unable to print from computer, nothing happens when i click print, yet printer will print from scanner. it is a h.p.psc1300 all in one.when i go into the printer on computer it says printer offline error...
I'm assuming it's USB and it got unplugged or turned off recently. Unplug the printer's USB cable for a bit (20 seconds), then plug it back in. Most likely the computer will recognize the new hardware and begin the software install that's needed. When you look at Printer on the computer again, you'll probably see a new one, but it'll show ONLINE. Make this one your default and delete the one that shows OFFLINE
I've had this happen to me several times and the above solution works for me. Good luck.
Jul 27, 2010 | HP Office Equipment & Supplies
Dymo label writer 400 turbo will not print
Uninstall the software and disconnect the printer from your PC. Then reinstall version 8 of the Dymo Software (without the printer connected) and connect the printer when prompted by the software.
Make sure you are using version 8 of the dymo label software - it is compatible with Windows 7.
Apr 24, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Mfc7340 will not print--it was working just fine and then it errors out. Uninstalled and reinstalled and it shows ready but errors out
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
  1. Clear the printer queue
  2. Shut down the computer
  3. Unplug the USB cable from your computer and your printer
  4. Unplug the power cable from the printer and wait 15 seconds
  5. Plug the USB cable back into the printer and the computer.
  6. Plug the printer’s power cable back in.
  7. Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thank you,
Mar 26, 2010 | Brother Office Equipment & Supplies
My HP Officejet J4540 All-in-one printer is showing Offline. I have checked all connections and all appears ok. Could you tell me how to change that status to Ready?
It shows offline if the printer is not communicating. Initially open printers folder and right click the printer icon and check if "use offline" option is not ticked.if its ticked then un-tick it. if everything looks fine then:
1)first try unplugging printer from main power cord for a minute and then plug back in and check after refreshing if it becomes ready.
2)other thing to do is to remove the usb cable from behind the printer and plug back in after 45 seconds.
3)it is also quite possible that the usb port or cable might have gone faulty.in that case try replacing usb cable and check.
thanks ,keep updated and accept the solution.
Sep 02, 2009 | Office Equipment & Supplies
Dymo LabelWriter 400 Turbo Thermal Printer Logo
3,052 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
