posted by madlad on Dec 14, 2007
The unit has no radio output,although it appears to be tuned with the correct frequency display,the aerial is plugged in,switching to mono makes no difference.The CD and tape players are working ok
Best Solution
posted on Dec 25, 2007
Hi MadLad,
There are several things to consider re this fault.....
Normally on small systems there is a selector switch to allow you to select what you need to listen to...for example if you want to play a CD then you select the CD mode, insert the CD push play and away it goes....
In your case you need to select Radio, or maybe select AM or maybe select FM, one of these should be accessed from a digital read out menu where you select your requirements.
Please have a good look at the operating manual to see if you can work out how to select the required listening mode, and you will be sweet...
Cheers From YUBEUT
Cheers From YUBEUT
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Denon DM-33 Shelf System
Email this problem
Email this problem
Can you Help with these Audio Shelf Systems problems?
Audio Shelf Systems
remote control failure and more
My slim cute remote for MC 320... Answer This...
Repair Service
Find Audio Shelf System Repairman Near You:
