Question about MA Audio MA 1200XL Car Subwoofer
Ma120xe sound horrible
I have to ma120xe subs (ma audio) and a d6 1500.1 diamond audio amp. the subs are dual 4 ohm voice coil (350 rms 700 peak) the amp makes "1500 watts" at 1 ohm i have them hooked up in a sealed box that i had jl w6's in they sound like crap tryin to figure weather its my amp the box they are in or the subs are just garbage?
Make sure that you have the subs wired in a 4-ohm series and not a 8-ohm load
Posted on Dec 23, 2007
What kind of amp to buy for an alumapro 10 inch sub 4ohm 250watts rms?
Is your sub single or dual voice coil. This will also make a difference in choosing amps. Pretty much any amp that will supply your required power will do. But, if you have a single voice coil sub, you will be wanting to look for RMS power at 4 ohms. If you have a dual 4 ohm voice coil sub, you can wire it to a 2 ohm load. Then you will need to search for amps that supply the RMS requirements of the sub at 2 ohms. The choices are almost endless. I am an RE Audio dealer, so I absolutely know that they will do you well. Hope this helps.
Aug 25, 2011 | AlumaPro BP-10 Car Subwoofer
I want a reliable system.
if you bought that equipment today then your answer is yes your amp will power the subs but if i was you and you want more bass I would go with a two channel amp or even a mono block amp that will be 1 ohm stable and if you decide to do that you might want to get subs that are dual 4 ohm voice coils and run them in series that will get you 1 ohm of resistance
May 19, 2010 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Volfenhag ZX4725 i am buying this subwoofer and
No the LOWER the resistance the MORE Output or Draw, If say it is 100 Watts into 4 Ohms, if you used a 2 ohm speaker it would draw 200 watts.(only if capable of delivering that amount of power) The LOWER the Resistance, the HIGHER the Current Draw. WATTS = AMPS x VOLTS. (This is not strictly true with amplifiers output though, as it is an AC Current, and a "Reactive" load, it has, Inductance, Capacitance and Resistance, all in one.and is worked out via a Formula) see below. http://en.wikipedia.org/wiki/Audio_power
http://www.hometheaterhifi.com/volume_1_1/v1n1spk.html
Now with Dual Voice Coils, Essentially, you can think of these speakers as TWO speakers in ONE enclosure. As such, They are basically TWO Speakers. Please see the website below it explains everything for you. http://www.diyaudioandvideo.com/FAQ/Wiring/
Everything is a function of Resistance and Ohms law.
Current (I) = Voltage (E) divided by Resistance(R).
Voltage = Current Multiplied by Resistance.
Resistance = Voltage divides by Current.
Apr 17, 2010 | Car Audio & Video
Need help wireing sub
Is the speaker a dual voice coil speaker? If so you can wire it up a couple of diferent ways, go to rockfordfosgate.com they have a woolfer wiring wizard that can show you the different ways to wire for 8 ohm.....4 ohm.....2 ohm....and 1 ohm...I would figure out how to get the most power out of the amp in mono mode, take that ohm load from there and see if you can wire your speaker to match it.
Oct 08, 2009 | Car Audio & Video
Why does the kenwood kac-9103d has two sets of terminals if its a one channel amp so how do i hook up a dual 12 phoniex gold 1200 watt sub to it
Hello damasogrizzl,
The 2 sets of terminals are connected internally. Having 2 sets just makes it more convenient when wiring multiple subs. The amp is rated for 900 watts RMS into a 2 ohm load. The specs claim that it is stable at 1 ohm but does not give a power rating.
The Radial SD competition series from Phoenix Gold are rated to handle up to 600 watts RMS. If you have the model RSdC124 with dual 4 ohm voice coils, it would be best to wire the voice coils in parallel for a 2 ohm load and connect the sub to one set of terminals on the amp. If your sub is the model RSdC122 with dual 2 ohm voice coils, you should wire the voice coils is series for a 4 ohm load and connect the sug to one set of terminals on the amp. Wiring the voice coils in parallel will result in a 1 ohm load. And, while the amp may be stable at 1 ohm, the sub will be seriously overpowered.
Hope this helps.
Sep 23, 2009 | Kenwood KAC-9103D Car Audio Amplifier
What is the rms and voicecoil configureation on these the older aw1200
here is all the specs for your sub
12" subwoofer with two 4-ohm voice coils
» carbon composite cone with foam surround
» heavy-duty cast-aluminum basket
» power range: 50-700 RMS watts (350 watts per voice coil)
» peak power: 1400 watts
» frequency response: 20-500 Hz
» sensitivity: 94.65 dB
» mounting depth: 5-5/8"
» sealed box volume: 0.50-1.50 cu. ft.
» ported box volume: 1.30-3.30 cu. ft.
Aug 04, 2009 | AudioBahn AW1200 Car Subwoofer
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
that subwoofer has dual 4ohm voice coils, if your amp can handle 2 ohms, you would put a wire from the positive (+) on the amp to the positive on both connectors on the sub, then hook the negative (-) on the amp to the negative on both the sub connectors that will be a 2 ohm load on your amp make sure your amp at 2 ohms is not more than 600 watts RMS or 1200 max.
Jan 01, 2009 | MA Audio MA 1200XL Car Subwoofer
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
How should I wire up this amp and sub
The amp's not actually a very good match for the sub, since the sub can be wired for 2 ohms or 8 ohms, and the amplifier is most efficient at 4 ohms in bridged mode. My advice would be to wire the amp in bridged mode, and wire the sub for an 8 ohm load. To do this, the amp's (+) wire should go to the (+) terminal on one of the sub's voice coils. Then run a wire from the (-) terminal on the OTHER voice coil to the (-) terminal on the amp. The remaining (+) and (-) terminals (on opposite voice coils) should be connected to each other with a wire. Your original wiring setup had the amplifier connected to only one voice coil, while the other voice coil was shorted.
Jun 10, 2007 | Kole audio Q2-480 Car Audio Amplifier
MA Audio MA 1200XL Car Subwoofer Logo
423 people viewed this question
Top MA Audio Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
hoyzee1
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
