Question about SanDisk Sansa E280 MP3 Player
Radio Function I have a E280 with the radio function disabled, I heard that this was due to some taxation import duty associated with the EU. I am also told that some user groups have a downloadable software fix to enble this feature.....anyone know of anything. Finally does anyone else find loading music into this device from media player 10 a complete pain in the a§$%&% I totally loose the tracks in the menu structure is it listed as artist, favourites, tracks, albums god knows I just have to keep searching to find where anything is regards to all
    Scholar:
  • 155 Answers
Here is a link for the firmwares, im not sure if this would help you but this is a very usefull firmware. Note : This could mess up your player and bring the error of "Load Main Image Failed"
Posted on Dec 15, 2007
How to disable the cb function on my harley?
Turn radio receiver ON and push the COM button (1). Push soft key 1 (9) to turn the CB ON/OFF.
Jun 03, 2014 | 2006 Harley Davidson FLHX Street Glide
Why don't the buttons of the keyboard function?
The button functions may be turned off so only the remote works. Look in the setup to see if you can disable front panel buttons.
Jun 02, 2014 | JVC KD-LX333 CD Player
Screen lock decode
Some Grundig/Eton radios have a button with a key lock symbol.Once the button is pressed it toggles between lock/unlock. In the lock status, the settings (frequency, time, scan, etc.) are disabled. Another function that is disabled is the Power On button. This feature prevent the radio to turn on if the power On button is pressed inadvertently when the radio is in a bag, or a suitcase.
Nov 07, 2013 | Grundig Audio Players & Recorders
How do i access the radio function on the phone so I can hear the radio when phone is hung up
If it's enabled in programming, background music is enabled by pressing feature 86 this will allow the set to play the music thats heard when a person is put on hold to disable press feature #86
Feb 12, 2010 | NorStar Meridian M7310 Phone
Transmitting
Hello lstimpson,
You may have the CTCSS privacy code function enabled on one radio and not on the other. This function keeps your radio's received muted unless it receives a signal from another radio using the same privacy code. If you have Privacy Codes set for radio A but not for radio B you will still be able to transmit from A to B but when you transmit on radio B your signal will not be heard on radio A.
Make sure that both radios are set to the same privacy code or that the function is turned off on both radios.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 19, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Repairing of my radio set
Hello mubidul,
Your radios may not be in need of repair at all. Many radios feature a privacy function (which Kenwood calls "Quiet Talk"). If this privacy function is activated on one radio but not on the other radio (or if the 2nd radio set to a different privacy code) the two radios will not be able to commuicate with each other. Based on your description I am guessing this is what's going on.
You will want to make sure that both radios are set to the same privacy code or that the privacy function is disabled on both units. You didn't mention which model(s) of radio you are working with so I can't give you specific instructions on setting the Quiet Talk / privacy codes. Consult the operating manual for your units.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 25, 2008 | Radio Communications
How do I get my motorola T5725 radios to talk to eack other
Hell ssalah,
Most of the time when one radio cannot talk to the other radio it means that the Privacy Codes are not configured properly. In order for the two radios to talk to one another they both have to be set to the same channel and Privacy Code or the Privacy Code function needs to be turned off on both radios.
The Privacy Codes can be used to keep the radios silent unless they receive a signal from another radio using the same code. This enables the radios to be used on busy channels with a minimum of interference. If Privacy Codes are turned off on one radio and turned on for the other radio, the situation you describe will occur.
Consult the user's manual for information on the Privacy Code function and either disable the function on both radios or set both radios to the same code.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 14, 2008 | Motorola Talkabout T5720 (7 Channels)...
My Binatone Marina 300 Walkie talkies give hiss & noise. Pressing menue and up or menu alone makes no difference. How can I have a quiet radio except when called?
Hello andy300,
Does the "RX" indicator show on the LCD screen constantly?
This radio does have a monitor function which disables the squelch control, allowing the user to listen to weak signals on the channel. Enabling this function in absence of any signals will cause the user to hear any background static or noise on the channel. You enable this function by pressing Menu + Up at the same time and disable the function by pressing Menu.
I assume that you are familiar with this function from the fact that you mention these keystrokes have no affect on the radio's behavior.
It is possible that the area you are using the radios in / channel you are using them on has a very high noise level. If the noise level is higher then the radio's automatic squelch threshold, then you would hear constant static, hiss, or white noise and the receive ("RX") indicator would show a constant signal. A local noise level can be caused by atmospheric conditions or very busy nearby adjacent-channel radio signals.
Try operating the radios on a different channel and see if that helps. If it is practical, you might try operating the radios in a different local area just to see if that has any effect at all. This would help you determine if the problem was a local one specific to the area you are operating in.
If it is local area related you might consider switching to a different model of radio that includes a Continuous Coded Squelch System (CTCSS) function (called "privacy codes" or "quiet tones" by come manufacturers. This function does not appear to be included in the model you are using and can help keep your radios silent unless you receive a call from another radio using the exact same privacy code.
If the problem persists regardless of channel or area, then you might have a problem with the radio that would require factory service.
Hope this helps. Best regards!
Ken
Go Ahead. Use Us.
Apr 21, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
The radio Function
try this link for the firmware of the player http://sansa.t03.us/ make sure you ahve the correct and proper device because this could open up the problem about load main image failed switch to recovery mode.
Dec 14, 2007 | SanDisk Sansa E280 MP3 Player
How to disable the ATT function?
If you can remove the radio from your dash, unplugging its wiring harness for a minute should solve your problem - you will also lose your saved settings like preset stations and EQ. What type of vehicle is it in? In some cars it is easier to remove the radio than others. If it is proving too difficult, you could try disconnecting the battery for a minute and that should cause the radio to reset also.
Sep 19, 2007 | Sony XPLOD CDX-GT200 CD Player
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
