Question about Panasonic KX-T7730 Corded Phone
Programming line I tried to program my phone for speed dialing and now the phone won't pick up the right line, it goes to intercom.
  • skerfis Apr 06, 2008
    i try to add speed dialing in kx-t7730, but i dont know how
  • Anonymous Mar 27, 2014
    When I pick up the phone to dial out, it immediately goes to Line 5 (of 5 lines), but we recently downgraded to 4 lines total. How do I program the phone to first start at Line 1 when dialing in or out and work up its way up to Line 4?
Press program then 1 and select what u need
1 for intercom
2 for co and select co No also.
for the speed dial store 9 before ur No
ie 9+123456789
Posted on Apr 18, 2008
My fone reseve the call but i trai tomake call but it do not make the call
Posted on Jan 08, 2008
Good morning
I just need a notice of functionalities of my device if you can to send it attached by E-mail
best regards
Posted on Dec 28, 2007
My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
Aug 20, 2011 | Avaya 700340193 Corded Phone
Hello, please i want to know how to set up speed dial on the KXT7730 that is not the main line ie not on 0, or 101 on the switch board
Guessing that you already know about SYSTEM speed dials, then the 12 buttons on the right side of your phone are the PERSONAL speed dials. When you get dial tone on the intercom, you can dial "9" and the system will either give you a dial tone, or the highest line in the system. If that is not a working line, you need to fix that first (system program 400 assigns lines in service).
Once you have that, a PF button is programmed by pressing PROGRAM, the button, and dial 9 + your number dialed the same way as if you had pressed a CO button then STORE. You can keep pressing PF buttons and programming numbers. Then press PROGRAM or pick up the handset and drop it back down to end programming.
Carl
Apr 21, 2011 | Panasonic KX-T7730 Corded Phone
How do I program a phone number to the one touch buttons on a Panasonic KX-T7730 phone?
It depends on what you get when you dial "9" on the intercom. If you get an outside line, then the 12 right side buttons on your phone can be programmed for one touch dialing like this:
On an idle phone, press PROGRAM a button and dial 9 plus the number and STORE. You can program more than one button by just pressing button numbers and STORE. Exit programming by picking up the handset and dropping it back down.
If you want a specific line, you may be able to dial the specific 8x code to access a line directly, or you can go into system programming and delete the open lines in program 400. Disabling would be the best, because if your 8x line is busy, you can't make the call with the auto dial button.
Carl
Mar 08, 2011 | Panasonic KX-T7730 Corded Phone
How to set name and contact number on the telephone set for one touch dialing with right buttons? My set is Panasonic KX-T7730
It depends on what happens when you dial "9" from the intercom. If it gives you a line, then that's your "access code". If it gives you a line that doesn't exist, then you need to fix your programming.
From the idle phone, press PROGRAM, one of the right side buttons, and dial 9 and your number and STORE. You can program one or all 12 buttons at once. When you're done, pick up the handset and drop it back down to exit programming.
That's it.
Carl
Feb 13, 2011 | Panasonic KX-T7730 Corded Phone
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
How do we set Personal speed dialling on KX-T7730?
Down the right side of the phone you have 12 Personal Feature buttons. Also, from the intercom, dial "9" and see if you get an outside line. If you don't, you need to fix that in system programming.
Now, from your phone, press PROGRAM, one of the 12 right side buttons, and dial "9" plus the number you want and STORE. You can continue programming all 12 buttons and when you're done, pick up the handset and drop it back down to exit programming.
You dial them by pressing speakerphone or picking up the handset and pressing the button.
Carl
Oct 20, 2010 | Panasonic KX-T7730 Corded Phone
Panasonic Kxt 7731
What happens when you dial "9" into the intercom dial tone? Is that the line you wnat to auto select?
A lot depends on the system your phone is connected with. In a TA series on an idle phone, press PROGRAM 11 for no preference (what you have) 12 for Idle line (what you get when you dial 9) or 13 and a number from 1 to however many lines you have to select a specific line.
Those commands are followed by the STORE button and PROGRAM to end the programming.
Carl
May 28, 2010 | Panasonic KX-T7731 Corded Phone
Avaya / Lucent MLS-12D Partner MLS12D Display Phone - BLACK: when A user picking the Avaya phone up, user don't...
get more lines.
Or check Auto line select.
From ext 10 or 11:
press feature 00
press left intercom twice
press right intercom once
enter extension number
press **
then press the lines in the order you want them picked up (line 5, 4, 3, 2, 1 then the intercom )
press**
press feature 00 to exit programming.
When the extension picks, it will pick up line 5. If 5 is busy, it will pick up line 4 , etc....
May 16, 2010 | AT&T Lucent MLS-12D Phone
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
I want to be able to just pick up the handset and have it
Depending on the software level, there is a possible chance for this to work...
first question though... can you dial a 9 to get a line out?
If this is possible, that means that we can change the PRIME LINE for a line pool access rather than intercom.
-> Get into system programming
-> get into TERMINALS&SETS and type in your extension
-> enter LINE ACCESS and hit next till you find PRIME LINE it should say I/C (this is intercom)
-> press change till you see PoolA
-> hit next and RLS to end programming.
Now everytime that you pick up your handset, it will pick the first available line out!
Feb 22, 2009 | NorStar Meridian M7310 Phone
Panasonic KX-T7730 Corded Phone Logo
238 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
