Question about Miele Dishwashers
Miele dishwasher pump wont stop wont fill with water
Dishwasher is about 7 yrs old taken non return valave of pump check pump runs dosnt stop so it wont fill is ther a sensor to stop the pump & start the water?
4 Suggested Answers
  • 122 Answers
We would have to order one -
Posted on Jan 04, 2009
  • 122 Answers
SOURCE: Locking clamp for non-return valve
It will have to be ordered from Miele
Posted on Jan 09, 2009
SOURCE: miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
Posted on Aug 14, 2009
  • 128 Answers
SOURCE: Miele G892SCB intake/drain light on.
Yes. 1 800 843 7231. follow the prompts to get to the parts department. have your model and serial number handy. They will get you the correct part. If you have any problems getting it in, or it doesnt solve your problem, repost. I will keep an eye out.
Posted on Nov 21, 2010
Testimonial: "thank you, you have been very helpful and have probasbly saved us a new dishwasher."
0 characters
1 Points
Miele dishwasher will not drain (G 2270 SCVI)
you need to replace the non return valve.
May 27, 2012 | Miele Dishwashers
Miele dishwasher drainage
there will allways be some water under the filter. when you remove the non return valve, there should be a rush of water coming back into the sump from the drain hose. if not, the seals in the non return valve are bad and you need a new part. they are not that expensive. switch to an appropriate detergent such as miele or finish all in one powerball tabs and the new part will last much longer. cascade and other brands are eating the seals in dishwashers faster than i can replace them.
Apr 03, 2012 | Miele Dishwashers
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: . The manual for the Miele G641 is here: . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
I have a Miele G2430 and it doesn't drain. I tried the baking soda and vinegar and it doesn't work. Is my pump broken or something? How much will cost to repair it if that's the problem?
Hi Jennyglopez..I do not think your pump is the issue,however you can make this checks.1-Take the filter combination out of the wash cabinet 2-Scoop the water out of the cabinet using a suitable container 3-Press the catch for the non-return valve inwards 4-Lift out the non-return valve and rinse well under running water.5-Remove all foreign objects from then on-return valve and drain pump 6-Carefully replace the non-return valve and secure it with the catch.Ensure that the catch engages correctly.You can also check drain hose &remove any kink in the drainhose.where the drain hose engages under the sink sometime gets clogged.Disengage the pipe & make sure hole in the drainage not clogged.Thanks & goodluck
Aug 18, 2010 | Miele Optima G2430SCi Stainless Steel...
My miele G665 SC is not draining all the waste water away at the end of the cycle, i've taken the filter part out of the bottom and it's all clear and even run a cycle without it, is there another filter...
Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
Jul 02, 2010 | Miele 24 in. G665 Built-in Dishwasher
I have a Miele Inspira line dishwasher and it is making a horrible sounds when I turn it on - like the water is not getting through easily
Hi If noise starts within one minute of start of program then you most likely have debris in drain pump. Under filter you will find non return valve remove valve this will expose drain pump impeller. with non return valve removed run program for 30 seconds refit valve and test. More in depth instructions available in user handbook.
Apr 11, 2010 | Miele Inspira Series Dishwasher w/ 6...
Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Sep 08, 2009 | Miele G892SC SS Dishwasher
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Intake/Drain Error
There is water collected in the inner tray of your unit. Pull out the Miele and take off the drain hose and unplug the unit. Then tilt the dishwasher back 60* and let it drain out all the water. There will be a couple of cups on the floor, but nothing too big that a couple of towles can't handle. Then reconnect everything and start up the unit. It WILL work! It just happened to me and my Miele incognito is now working like a champ again!!
May 21, 2007 | Miele 23 in. Novotronic G841 Built-In...
Dishwashers Logo
171 people viewed this question
Top Miele Dishwashers Experts
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
