Ecoquest Fresh Air Air Purifier
Problem for Ecoquest Fresh Air Air Purifier
Machine has been off for 6 months. Plugged it
By nancymac78 on Sep 21, 2009
Machine has been off for 6 months. Plugged it in& LCD display on partly shows.
Solution #1
posted on Oct 04, 2009
Not Rated)
lldenney
Rank: Guide
Rating: 0%, 0 votes
If you mean the LCD is only partly showing, it should be replaced. Just sent in two for the same problem with clients. Apparently, supplier switched to cheaper parts, causing this. Should be under warrantee. Call fast. If you never set up the warrantee, you should do that first. I'm "SURE" you bought it less than 3 years ago...Right???? (Hint) 800-989-2299
Was this helpful?
Yes
No
Popular Solutions for Ecoquest Fresh Air Air
Questions and Unsolved Problems for Ecoquest Fresh Air Air
Do you recommend Ecoquest Fresh Air Air Purifier?
Answer
Answer
I re[laced the lamp and charge on my Fresh Air purifier and the display still says replace lamp. Whi... (More)
Answer
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest... (More)
Answer
I have 2 ecoquest fresh purifiers 1 will not power on would that be a fuse issue and the 2nd the... (More)
Answer
install plate? no i just cleaned and now it won't work. it says to install plate.
Answer
unit cut off about every 2 minent then come back on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Fresh Air Air...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2540
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
