Question about HP ProCurve 4104gl Networking Switch
HP Pro Curve 2650 switch j2899a
When trying to copy files with client connected to switch it says a 'delayed write failure message'
I do not know what to do.
  • 51 Answers
Because you dont have sufficient privilages to do so please contact your system admin as early as possible...
thank you..
Posted on Jan 05, 2008
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    Hiii... I am having a 500 G.B. external hard disk. whenever i want to perform any operation on it such as "Copy to PC" or "Copy From PC"... it displays an error message after some time...
    This is Microsoft's answer to this problem.
    This error typically occurs when the "Enable write caching on the disk" feature for your hard disk is turned on.
    However, if the "Enable write caching on the disk" feature is turned off, this error can occur because the Ultra Direct Memory Access (UDMA) hard disk controller may be configured in either of the following ways:
    • You are using a 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
    • The BIOS settings are configured to force faster UDMA modes.
    For more information about the delayed write failure, go to the "Delayed Write Failure information" section.
    Jan 21, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    Our hp 2650 when boots up all the grn and org lights continually stay flashing what could be wrong, although 1 port doesn't flash and works
    It could be a Failure on those Flashing Ports, try to console in to the Switch and access the event log to verify that. try the troubleshooting part of the manual at this link, see if it helps: http://ftp.hp.com/pub/networking/software/Mgmt-Oct2005-59906023-AppC.pdf
    cheers
    Aug 19, 2010 | HP ProCurve Switch 2650
    Hp 4700 has come up with message scan failure unable to scan or copy
    Open the given below link and perform all the steps in that:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01611346&cc=us&lc=en&dlc=en&product=3794615
    If your issue gets fixed, please come again to give us a
    vote which will really motivate me to help people in
    future.
    May 10, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
    DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
    Oct 13, 2009 | HP LaserJet 4250n Printer
    My system did an automatic update. Now I get a message that says that my backweb-137903.exe has been moved and so my HP center does not load. I looked for the file but it is not present on my PC. I also...
    This error message probably occurred, because a spyware removal application incorrectly detected the Updates from HP Connections or Compaq Connections client software (developed by BackWeb Technologies), as spyware and improperly removed it. Since only part of the client software was removed, the errors displays because the software cannot fully open when Windows starts. Updates from HP or Compaq Connections is a messaging service that comes pre-installed on HP and Compaq desktop computers. The service provides product notices, support updates, tips, and special offers specifically for your model of HP or Compaq PC. If you no longer want to use Updates from HP or Compaq Connections, HP or Compaq Connections can be uninstalled through Add/Remove programs. If you still want to use HP or Compaq Connections to receive information regarding your PC, complete the following steps: CAUTION: Performing a System Recovery replaces system files and original software with the files that originally came with the PC. This process may move or remove certain files, like those stored in My Documents. Before performing a System Recovery backup important files and the files stored in the My Documents folder.Be prepared to reinstall software that was not originally included with the PC. You will also need to reconfigure an Internet Connection and obtain all critical Windows Updates, Virus definition updates, and anti-spyware updates. To resolve this error, reinstall the Updates from HP/Compaq Connections client software by performing a standard recovery:
    1. Remove all connections from the PC except keyboard, mouse, monitor and power cable. If any internal hardware such as a video card, or sound card has been added, they should be removed or disconnected.
    2. Restart the computer and press the F10 repeatedly after the logo screen appears.
    3. Click Next when prompted.
    4. Read and respond to the screens to recover the computer.
    After the computer is recovered and you have completed the setup, you can do any of the following items to prevent the error message from displaying:
    • Adjust the settings in the spyware removal application to bypass the Updates from HP or Compaq Connections client software.
    • You can uninstall the Updates from HP or Compaq Connections client software before using your spyware removal application: Uninstall Updates from HP or Compaq Connections client software by clicking Start , Control Panel , Add/Remove Programs , Updates from HP/Compaq Connections , and clicking the Remove button. NOTE: If you remove the Updates from HP or Compaq Connections client software, you should visit the product support page for your PC model, HP Support and Drivers Search , for the latest information and software updates.
    HP does not consider HP or Compaq Connections spyware software. If spyware removal software detects BackWeb as spyware and you would still like to remove HP or Compaq Connections, it should not be removed through the Spyware removal software. Instead, uninstall BackWeb using Add/Remove Programs as shown above.
    Oct 05, 2008 | HP Computers & Internet
    Hidden Program
    In Windows 98 the MS fax client is installed as part of the windows messaging package and uses a mapi client like exchange client, outlook, or windows messaging to work. Try 'add/remove software' in the control panel and see if you can unistall windows messaging. If you have the win 98 install cd, there is a file called wmw-fax.txt in the tools/oldwin95/message/us folder. you might find the information in there.
    Apr 07, 2008 | Microsoft Windows XP Professional With...
    Copy on my 2179 hp all-in-one
    Hi Simoandson, The scanner failure message usually occures when the scanner bulb is not getting heated properly or the scanner bulb is defective. We can check with the issue by connecting the printer direcly to wall outlet and then lift the scanner lid and press scan or copy button and check for the scanner bulb is lit and scanner machinisum is moving fine under the scanner bed.. There is also a Firmware update released by HP that can be downloaded and installed to fix the issue: Here is the link: ========= http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en ======= Just click on the link and in the download webpage click on the download only button and select save to save the download to the computer and once the file is saved make sure that the printer is turn on and connected fine and click on the file to install the firmware update to the unit If the issue still presists try to performe the steps in the below webpage: =========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=us&lc=en&dlc=en&product=1138346&dlc=en&lang=en ======== Hope this will help you to fix the issue Regards, Barret.
    Sep 02, 2007 | HP PSC 2175 All-In-One InkJet Printer
    HP ProCurve 4104gl Networking Switch Logo
    153 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
