Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn -air side by side model #JCD2289AE serial #10431655US
I need a manuel for this refrigator and i can not seem to find one or is this the right numbers
Thanks! Copy the URL into the address line in two steps using Ctrl/c to copy and Ctrl/v to print. Works fine.
Posted on Feb 25, 2008
    Problem Solver:
  • 12 Answers
Try this site=
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JCD2389G&siteCd=JA_EN_US
Posted on Dec 14, 2007
  • Frank  Castorani
    Frank Castorani Dec 14, 2007
    New at this I guess the address was to long for this site, I'll try again in a few.
  • Frank  Castorani
    http://shared.whirlpoolcorp.com/product_...
    Had to split address to fit, no space between first and second line.
    Frank
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
The jenn-air fridge that i have jcd2289ae has stopped working it is tripping the gfi, i have tried plugging it in another plug in but it trips the breaker
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2289AEQ/1266/0165000/M0406284/00012?blt=06&prst=&shdMod= here is a simplified wiring diagram for your unit. It might help you track back the problem.
Before it started tripping the circuit breaker what was your refrigerator doing that was not normal? Usually, before something fails massively it will give you hints it is coming. Did your ice maker or lights stop working? Has the compressor been running an excessively long time?
What trips a breaker is the unit drawing more current that what the breaker is listed at. So something in the unit has shorted to cause this to happen. Although the first thing we check in a situation like this is the compressor circuit it isn't always the cause.
Jun 26, 2011 | Jenn-Air 21.6 cu. ft. Side-By-Side...
I have a Jenn air side by side refrig/freezer
Hi rdiorio.
you could have one of many faults, either thermostat, compressor or if electronic maybe that have failed. If the Thermostat starts to fail it can produce eratic readings which freezer the chiller part of cabinet, then it can fail completly. What ever you do remember 240 Volts kills. Use a qualified person when dealing with electrics... Cheers
Mar 29, 2010 | Jenn-Air JCD2389G Side by Side...
The drain pan in the bottom of a jenn air refrigerator
Remove the 2 screws , holding the freezer panel on , to gain access to the drain . The pt number for the housing is 61003830 . You may have to remove 2 screws to remove the housing .
Nov 11, 2009 | Refrigerators
The piece that connects the vertical hinge to the door is broken.
Try partsdirect.com they have one of the best parts resources available. you will need your complete model number off of the inside of the unit it is located either on the eiling or right hand wall of the refrig section. thx Peyton
Mar 16, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
IS THERE A RECALL ON JENN-AIR REFRIGERATOR, MODEL #JCD2389GE ?
MAYBE!  Our Jenn-Air side by side has a similar model number to yours and it was recalled on March 10.  Check on maytag's recall page to see if your fridge has been recalled by entering your model and serial number.
Mar 11, 2009 | Jenn-Air JCD2389G Side by Side...
Grinding noise on right side of refrig ceiling
sounds like a relay in oyour adc(adaptive defrost control) is getting stuck causing the "chattering noise" you can replace the control easily for about $50.. the top cover pulld straight out and a few screrws hold the top panel up, to reveal the control box in upper right corner. turn off power before attempting lotsa wiresup there
Mar 02, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-Air not Cooling...
Sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
Feb 15, 2009 | Jenn-Air JCD2295K Stainless Steel Side by...
Everything in My Freezer is Melting and Fridge is getting warm!
find another place for all of your food because you may need to call a service company.
possible causes: stuck in defrost (if nothing is running) bad compressor (if fans are still running) freon problem if everything is still running
Jun 28, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn Air JCD2389GTW Refrigerator problem
change the adaptive defrost board located in the upper right corner of refrig under the panel. remove panel by pulling on panel towards you from the finger holes in the rear. remove two 1/4 inch screws and two phillips screws. defrost manually with hair dryer behind panel in freezer.
Jan 19, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
801 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
