Samsung SP47W3HF1X Makes a noise to say it is coming on, then makes a similar noise in reverse and does not come on
  • gavync77 Nov 24, 2009
    i had one of these tv's given but i got now remote "where could i get one"???
  • 4,402 Answers
Common problem with these sets is the convergance ic's
however with out troubleshootingSamsung SP47W3HF1X - 2.gif it it's hard to tell you might want to contact pts see how much to fix the board.
Posted on Dec 14, 2007
Transmission problems
It could be a sign of bad transmission solenoid. If so, your vehicle has trouble shifting into drive or reverse. Normally, when you start your car, you're able to shift into drive or reverse right away. With a bad transmission solenoid, the vehicle could have a delay of a few seconds, or even take several minutes to warm up and operate properly. During this delay, the vehicle will act similar to how it behaves in neutral. It won't stay in park, and when you press the gas pedal, the vehicle will make an engine revving noise but not move.
Oct 03, 2013 | Toyota Avalon Cars & Trucks
Acura 3.2 tl makes a noise when started in the morning in cold
that noise is 1 of your belts. there is 3 belts on it. and with the power steering noise I think it is your power steering belt needs to replaced or agjusted
Nov 11, 2012 | 2005 Acura TL
My 2001 tahoe makes a loud clicking noise in forward motion. The faster you go and the warmer the vehicle is it goes away. Then in reverse it makes a loud scraping noise. Help plz.
how well does reverse work and check color and level of trans fluid with engine running and warm also feel for grittyness of fluid if gritty and browning your trans may be going out
Apr 01, 2012 | 2001 Chevrolet Tahoe
Sounds kind of like a crunching sound? right front end in drive, left front end in reverse, has all new frame bushings, new struts with springs and bearing plate, new brakes, front end shop sees nothing...
Seems like the noise is related to torque reaction from the engine/power unit that can move quite a lot under acceleration/deceleration especially if an engine mount is soft or broken.
Perhaps the exhaust or similar is badly positioned and is too close to the bodywork.
Searching for a noise that can't be duplicated on a workshop hoist needs imagination and some carefully placed brute force...
Oct 19, 2017 | 1997 Buick LeSabre
I just started having problems today. 2001 ford f150 . It felt like tranny was slipping. Checked fluid, a little low, topped it off. truck goes into reverse but wont move backwards. truck moves forward...
Sounds like the rear end differential is going out. I had a similar problem on a customer's truck, and it was the differential in the rearend. Replaced the rearend, and the noise was gone.
May 28, 2010 | 2001 Ford F150 Styleside SuperCrew
Weird noises in drive and reverse
The high pitched whine in reverse sounds normal for a honda. Ever honda I have had makes a similar noise while in reverse. The spinning, scraping noise in drive is not normal. You might want to see a mechanic about that.
Apr 30, 2009 | 2002 Honda Civic
New 14 seer split ruud heat pump makes very loud knocking noise
Well you may want to have a tech come out and check the freon level, but mostly when going into defrost, some units make alot of noise, the freon is reversed in the unit by way of the reversing valve, it makes a whooshing sound like freon is draining off, as far as the knocking noise, could be as I said in the beginning, might be low on freon, but it could be that, this particular unit does this, I have had units make some really strange noises in the past but functioned perfectly, hope this helped, please let us know, thanks again,
Jan 24, 2009 | Ruud UAMB Air Conditioner
Televison & Video Logo
387 people viewed this question
Top Televison & Video Experts
