Question about Whirlpool Duet GHW9150P Front Load Washer
Spin cycle off balance and clothes still wet.
We noticed the clothes still wet, so I tried to put them through spin cycle again. As soon as it started to spin I could see the tub was way off balance and the struts below were overworked. The pump was also making an abnormal noise, so I stopped it and cleaned drain trap. When I looked on the inside of the tub behind the rubber boot, I found a piece of flat wire (clip?) that had been painted white. I would imagine that this is what has caused the problem. Where did it come from? How do I replace it?
Thanks.
  • whatnext Dec 15, 2007
    You are 100% right. My girlfriend came over right after I had posted the problem, and looked at me like I was wack for not knowing what it was...as if I wear them...or would take the time to study the packaging the present was wrapped in.
    As for the major off balance, it was the result of having one of those membrane type bed liners in the load which had bundled up and trapped water because the cloth side was turned in. Just turned it cloth side out and put back in for spin cycle. Problem solved.
    Got to really get to know my machine though by taking the panels off. Thanks.
    Champion:
  • 249 Answers
That piece of 'wire' is a bra under wire,I kid you not.I have taken out hundreds over my thirty years repairing machines,they do go into pumps and make alot of noise,your right,that was your problem.!they say bras are to be hand washed,but nobody does!!close,eire!good ,luck!!!
Posted on Dec 15, 2007
Spin cycle is not getting clothes completely dry, can still hand ring water from clothing
When the clothes are wet at the end of a cycle, check these: Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 01, 2010 | Maytag Washing Machines
Cloth are still very wet after wash (it used to be very dry and it started happening since last week)
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Feb 07, 2010 | Kenmore Washing Machines
Clothes are to wet after spin cycle
Jan 24, 2010 | Kenmore Washing Machines
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Towels come out soaking wet, too wet to put in dryer. When placed back in dryer, noticed the spin cyle runs slowly, never spinning fast. The drum itself isn't solid, but oscillates when spinning.
Jan 01, 2010 | GE WSXH208A Front Load Washer
Machine won't rinse or spin properly..also stinks!
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
May 08, 2009 | Maytag HAV2557 Top Load Washer
Clothes wet when cycle is done
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt , a worn clutch , or a worn motor pulley or tub bearing. Replace the applicable component.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | Whirlpool Washing Machines
Clothes were still very wet when cycle completed
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 14, 2009 | Bosch Nexxt 500 Plus WFMC5301UC
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 02, 2009 | Kenmore 43142 Front Load Washer
Spin cycle leaves clothes very wet
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Feb 09, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
180 people viewed this question
Dan Webster
Dan Webster
Sal De
