Question about Lexmark X5150 All-In-One InkJet Printer
Plug-in card the Printer on/off button flashes and the printer will not startup. I follow the tips (unplug and replug both cords to the printer) the end that plugs into the printer is hot. Sometime this eventually will cause the printer to print. Other time it does work.
    Master:
  • 619 Answers
Check your convenience outlet lose connection ,it will cause spark or hot the plug , replace the outlet ,
Posted on Dec 31, 2007
Prints multiple copies of job and will not shut off or stop printing
Unplug the power cord from the printer. Hold down the red "X" button. Plug the power cord back in while holding down this button. Release the button. Should see flashing red and green lights. Unplug the power cord again. Replug. Should be reset.
Apr 10, 2011 | Dell 1100 Laser Printer
I have E code then a 3 showing up, printer will not pull paper through, can find no paper jam..
Press the black or color button.
If this does not work.
Unplug the printer from electrical outlet.
Wait at least 2 minutes.
Do not just unplug and replug.
Plug back in printer.
This will reset the printer.
The printer will recycle during startup.
Jan 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Pressing the button to switch on but nothing is happening could it be a fuse or do I need to buy a new printer?
Go through the following checklist:
  • Plug printer straight to power outlet in the wall. Bypass any surge devices or power strips as they can draw away power from the printer.
  • Properly secure the power cord.
  • Unplug the power adapter from the printer, replug after 30 seconds. The power adapter is the rectangular black box, behind the printer where the power cord is attached. Check if it's warm or cold. It can be a defective power adapter.
  • If you have access to a voltmeter, test power adapter(30V output).
If problem continues, contact Lexmark technical support.
Sep 20, 2010 | Lexmark X1150 All-In-One InkJet Printer
Printer is showing "error: 0xf0af0001 Reset Power". I have unplugged and then plugged in printer multiple times and printer comes ok for about 30 seconds and then the same error message appears will all...
last month i had same problem and i contacted customer care and i got this solution. And this works.
Step 1:
Perform a partial reset.
A partial reset returns the user settings to the factory defaults. The language and country/region settings may also be deleted.
Please perform the partial reset using the following steps:
a. Unplug the power cord from the all-in-one.
b. Press and hold the "#" and 3 button on the front panel keypad.
c. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one begins to initialize.
If the issue persists, follow Step 2.
Step 2:
Perform a semi-full reset.
b. Press and hold the "#" and 6 button on the front panel keypad.
Jun 24, 2010 | HP Officejet 5610 All-In-One InkJet...
I have an MP530 printer - error message 5C10 is
You could try resetting the printer:
1) On the panel, press and hold the <On/Off> button until the display goes blank (approx. 1 second). If the display does not go blank, unplug the power cord.
2) Wait approx. 10 seconds, plug in the power cord (if removed in previous step), press the <On/Off> button to power on the unit.
3) Wait for the printer to cycle through its startup routine before trying another print job.
I hope this helps!
Jan 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
All the lights are flashing and it says to Reset power. I disconnect the power cord and reconnect. The system looks like it is resetting and then the same flashing lights appear and it again says to Reset...
Hi Joe,
Lets try 2 steps:
1st approach:
1. With the printer “ON” unplug the power cord form the printer.
2. With the printer now unplugged, press and hold “# and 6′ keys in the printer..
3. While still holding these keys down, plug the power cord back.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
2nd approach:
1. Unplug the power cord
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
(repeat 3 times)
If none of these to approaches work, I’m afraid the failure is “fatal” as the main circuit board might be fried L
Regards,
Ed
Nov 25, 2009 | HP Officejet 6310 All-In-One InkJet...
My canon bjc 80 wont print and error light continually flashing
Indicates Waste Ink Full error
To repair follow the steps below
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Mar 28, 2009 | Canon BJC 80 InkJet Printer
Copy
- try doing the power cycle.
- unplug the power cord w/o turning off the unit
- wait for about 2 minutes.
- replug the power cord.
- then try to do copy again.
- if still not working, try to press set-up go to tools and clean the printheads. if still not working go to next steps.
- took all the cartirdges out.
- clean the electrical contacts of the cartridges and the carriage with a lint free cloth moisten with an alcohol.
- wait for 30 seconds
- replug the power cord and install the ink cartridges if the printer ask them to install
- try to do a copy
- is still not working
- try to do a reset
- unplug the power cord again
- then press and hold the # and 6 key while the printer is unplug
- and while holding them both replug the power cord
- then do not yet release the two buttons, wait for the printer to start up and if the screen turns off thats the time you will release the two buttons
- then follow the on screen instructions.
Aug 25, 2008 | HP Officejet 6310 All-In-One InkJet...
Overload
Hi
Your printer was pawered ON during the Lightening if yes then follow the steps, Try with the different power card if it having the same problem then most probably your printer fuse blown open the printer and check the fuse if the fuse are OK then please check with the service centres
Boopathy.T
Aug 16, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HPc6150 printer error
Hai
I Seems to be a hardware problem.Follow my troubleshooting steps.
STEP 1:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.(if it doesn't works goto step2)
STEP 2:
PARTIAL RESET:-Take the Ink cartridges out, Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
STEP 3:
SEMI_FULL RESET:-Take the Ink cartridges out, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
STEP 4:
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
If they don't work, the printer needs to be serviced.Let me know the status.
Thanks
Riz
May 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
Lexmark X5150 All-In-One InkJet Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
