Question about GE GSS25JEMWW Side by Side
Door handle coming off
My sidebyside is barely a year old and is only being used by one person. The door handle on the refigerator side is coming off at the top. I can see the two screws but have no idea what to do to re-tighten them. Someone said to remove the inside of the door, but I don't know how to do that either. The bottom of the handle is now beginning to loosen, too. I'm opening it by using the top of the door, but I'm afraid one of my grandchildren may visit and use the handle, pulling it the rest of the way off. I don't think this is covered by the warranty because the refrigerator was delivered (but not used) a year ago last month. What do I do?
  • 126 Answers
First check with dealer about your warranty if not there are screws under the gasket to remove inside liner.
Posted on Dec 14, 2007
A loose door handle on frigidaire refigerator
There are usually some hex head screws on the upper and lower sides of the handles make sure they are tight.
Nov 29, 2014 | Electrolux Genuine Frigidaire Refrigerator...
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
My two year old admiral refigerator has air entering freezer part
lube the hinge side, sealing face of gaskets with vasoline. Heat gaskets with hair dryer then tape doors shut when hot. wait an hour before removing tape. do this on both doors.
Aug 26, 2009 | GE GSH25JFR Side by Side Refrigerator
My maytag refrigerator sidebyside ice maker stop working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnc
Jan 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Loose handle
yes , on most freezers the door inner panel liner needs to be removed , that will sometimes require the removal of the door gasket that may be old to the point where it to needs replacing. then finally you can get to the back side of the door and snug up the screws that hold the handle from the back. usually fine thread screws. be sure to apply loc tite and snug up good , we don't want to do this again any time soon. you can take a chance and try pulling out the handle and cutting the screws and then drill the hole in the handle out to where you see a hole in the side of the handle from the front, then counter sink the hole and use a drill screw or a small toggle bolt to resecure the handle . no real wires or refigeration tubes in the door, so its an option. good luck
Nov 24, 2008 | Freezers
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
now you just need to buy another handle because the first one is not fixed well, it doen't cost a lot, but when you buy the handle you get free maintenance.
Mar 04, 2008 | GE GSS25JEMWW Side by Side
GE GSS25JEMWW Side by Side Logo
80 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
