Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
No IP address via LAN (+)
I cannot get IP via DHCP. I couldn't find modem when I manually installed IP (10.0.0.xx, 192.168.1.xx and 192.168.0.xx)
nmap -v -sP showed that only one host is alive - my PC.
How can I get connected to the device? What is the problem? Reset doesn't make any effect.
tcpdump shows nothing while I'm connecting via DHCP.
  • stop_it Dec 14, 2007
    S/N: PH06172011274
    mac: 00195BC72105
    New Friend:
    Problem Solver:
  • 12 Answers
I think you may have a problem in connecting or you did some mistake while connecting.So better use correct connection method then check ip address is detected or not.To check ip address visit the site www.ip-details.com If you have still same problem in modem or in any device.Please call some technical person and connect it.
Posted on Jun 17, 2013
  • 38 Answers
What reset did you do?
assuming you reset router by unplugging then plugging back into power source?
back up current config file first, to save your settings, reset to factory settings, power cycle.
Posted on Dec 14, 2007
SOURCE:
How to install router wr740n v4 without resource cd
Milan have you got the user manual as it clearly explains how to set up the router and configure it manually !
http://www.tp-link.com.au/resources/document/TL-WR740N_V5_User_Guide.pdf
Your modem device already on your network has to have an IP address of 192.168.0.1 and according to the user manual the router detects the conflict in ip address and allocates its IP address as 192.168.1.1. If you IP address is different say 10.0.0.1 then you will have to plug just the router in to your Laptop and alter the i/IP address to 10.0.0.2 and turn off the DHCP server if the modem or existing router has DHCP. You will need to alter any existing DHCP server to have the first 10 IP addresses skipped for available leases to the computers.
Feb 07, 2015 | TP-LINK TL-WR740N Router
NEED TO CONFIGURE IP ADRESS ON SP3410DN. DHCP is set to off. How do I fix it?
Hi
If you go to this page you get the option to download a manual for this machine in ZIP format, or to view the manual in your browser:
Aficio SP 3400N 3410DN download page
I suggest that you download the ZIP and expand it to your computer so that it is available for future reference.
The easiest way to get this onto your network would be to turn DHCP on, and let the printer get an IP address from the DHCP server on your network.
Otherwise you must find out the IP range for network, the Subnet address, the Gateway IP address, and the DNS server address, and enter them all onto the printer.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 05, 2015 | Ricoh SP 3410DN Laser Printer
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
I want to set up my new HP PHOTOSMART eSTATION C510 series Printer. Where I bought my printer said I would need a router. So I bought a new CISCO linksys E1000. When I got home and started to get...
. The printer's instruction guide should show you how to set the printer's IP address ?
it has to be in the range of what the modem / router you already have is.
If set to auto ip address on the printer
The existing modem / router would have a DCHP server most likely you could log into this router and look sat the ip leases and when it allocates a lease to the printer you set it as Static or permanent lease. There would be an ethernet port on the back of the router to plug in your printer to.
If manual setup then log into router / modem and set the dchp leases to start above 10 . it would be xx.xx.xx.1 to xx.xx.xx.254 just change it to xx.xx.xx.10 to xx.xx.xx.254 and xx means whatever it is set to for its network address. eg 10.0.0.1 - 10.0.0.254 . Set the printer to ip address to eg 10.0.0.9
On your MAC you may need to download and install a printer driver .
Mac is very clever and may set up the printer once you do this automatically by detecting the printer and setting it up in the MAC
If it is a wi fi printer you need to know the encryption settings by logging into the wi fi router and then set this up on the printer ?
May 13, 2017 | Computers & Internet
Need to change my IP address, it wont log on to internet because the IP address starts with 169
The problem seems to be with the Win CE DHCP only working with a router configured as 192.168.1.1. My wireless router is configured as 192.168.0.1 and it is a no go for both wireless and wired. But if I plug directly into the DSL modem that is configured as 192.168.1.1 then the netbook works. If the netbook does not find a DHCP router then the AutoIP kicks in and assigns the netbook at 169.xx.xx.xx address which is out of range of most routers. So you router will need to be configured with a LanIP address of 192.168.1.1. Hopefully you ISP can help.
Sep 09, 2010 | Sylvania G-Netbook
I cannot conncect to the internet and it says that my Intel/pro w
When you get home, do the following:
  1. Connect your computer to the modem with an Ethernet cable.
  2. Go to start -> Control panel -> Network Connections
  3. Find a connection called "Local Area Connection"
  4. Right-click and choose "Properties"
  5. Scroll down until you see "Internet Protocol TCP/IP"
  6. Double click it.
  7. Make sure that both buttons for "Obtain...automatically" are checked.
  8. Click "OK" until all windows are closed.
  9. Open a command prompt (Win-key+R) and type "cmd"
  10. In the following window type "ipconfig /release"
  11. When that is finished type "ipconfig /renew"
  12. When that is finished, type "ipconfig /all > C:\fixya.txt". This will create a text file on your C: drive.
  13. Copy the contents of the file and post it here as a comment, if you still can not access a webpage.
I will bookmark this page and come back here later or tomorrow to see what you posted.
For your info, my output looks like this:
Windows IP Configuration
Host Name . . . . . . . . . . . . : [computername]
Primary Dns Suffix . . . . . . . : blabla
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . :
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Connection
Physical Address. . . . . . . . . : XX-XX-XX-XX-XX
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
Lease Obtained. . . . . . . . . . : Friday, August 07, 2009 09:35:22
Lease Expires . . . . . . . . . . : Saturday, August 08, 2009 09:35:22
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet
Physical Address. . . . . . . . . :XX-XX-XX-XX
IP Address. . . . . . . . . . . . : 192.168.1.60
Lease Obtained. . . . . . . . . . : Friday, August 07, 2009 09:35:16
Lease Expires . . . . . . . . . . : Saturday, August 08, 2009 09:35:16
See you later!
Aug 07, 2009 | Dell OptiPlex GX270 PC Desktop
Dropping ip, or conflict with modem ip
try setting your router to use 10.10.10.1 and give out DHCP of 10.10.10.9-99 as a range. 10 network is private and will insure the issue. More than likely both are trying to use 192.168.X.X networks
Jul 08, 2009 | ASUS WL-500W Router (WL500W)
Cannot connect it to Linksys wireless router.
try setting it up for DHCP and let it obtain its on IP address from the router.
May 29, 2009 | Zyxel Prestige 660M (P-660M-61)...
How to analize how many system are working in my network and how i trace them what they exactly done.
you need angry ip scanner and nmap angry ip if you set it to scan for example 192.168.1.1 through 192.168.1.254 it will tell you all the active i.p.s on local network 192.168.1 and what the device name is and nmap will tell you what what packets are being kicked around on your network.also you can look in your router and look at the log and dhcp list but i think nmap and angry ip work better also you can use a packet sniffer like wire shark to analyze the traffic. hope i gave you some help in solving your problem.
Apr 09, 2009 | Microsoft Windows Vista Home Premium with...
D-Link DFE 916
The D-Link DFE-916 hub is unmanaged, there is no web management console. You will need setup your broadband modem setup as DHCP to assign your workstations IP address, (or you could go static IP, but DHCP is suitable for most situations)
Topology should be like this:
MODEM-----Hub/Switch-------Computer.
here the link the manual,
http://dlink.support.etop.pl/manuals/dfe916.pdf
concerning the bandwidth pirate, you will need the offending computers mac address, (Media access Control)
to do this:
click start,
Run,
type in: ipconfig /all
the line that reads: "Physical Address" is the MAC address
the format will read like this: xx-xx-xx-xx-xx
Now check your broadband modem or you routers management console for a MAC filter, this is where you can allow or ban a device or computer from the network.
Good Luck!
Jan 01, 2008 | D-Link DFE 916 (DFE-916) Networking Hub
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
267 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
