Question about Kenmore Elite 45986 Front Load Washer
Kenmore Front Load Washing Machine
My Washing machine is a Kemore Front Load. It is 6 1/2 years old . I was doing my Laundry and suddenly I heard a loud noise , When I looked there was water all over the Laundry room floor. I called in a Sears technican who advised me that it would cost me $400.00 as there is a plastic piece inside the drum that has to be replaced. Can you help me with this situation as I cannot understand why the cost. Also would you know if this is under warranty as I have not been able to locate my booklet and Sears is of absolutely no help.
Thank You
  • Anonymous Sep 04, 2008
    same thing with my washer---sears is no help at all.  For someone to look at machine, it is a three week wait.  Bad customer service. Expensive machine-only 6 years old, last washer laster 15 years with no major repairs.  Never buy again.
I have the exact same problem and they told me the parts were not under warranty only the drum (which apparently is not the cause of the leaking water and loud banging noise during the spin cycle.. Seems my repair will cost $600 plus the service call. After searching the net I found a smiliar posting that stated the 'spider bracket is broken' and not the drum. Still dont know what Im going to do..probably cheaper to purchase another machine.. Not much value for only 6 years of use.
Posted on Jan 21, 2008
    Master:
  • 619 Answers
Warranty is free of charge the only they may charge is material they use .
Posted on Jan 10, 2008
No power to the lg washing machine
This is a hard problem to diagnose remotely. Someone has to have a look at the machine, as any number of electrical/electronic failures could cause a loud popping noise. I would recommend a service call.
Apr 14, 2014 | LG WM2077CW Laundry XL Front Load...
Front loader has gotten really really loud and shakes the whole floor when it spins properly. Today it left a lot of water in the clothes. It used to make a weird whining noise when it didn't spin out...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | GE WBSR3140DW Top Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
We have a ge washing machine model number WJRE5500G1WW. We were starting a new load of laundry and the washer was just filling with water. There was a loud noise we stopped the machine and it looks as if...
We have a ge washing machine model number WJRE5500G1WW. We were starting a new load of laundry and the washer was just filling with water. There was a loud noise we stopped the machine and it looks as if the entire central component that holds the washer separated from the metal shell. It is no longer suspended from the outer support framework
and is floating unsupported. Do you know what we should do to fix this
May 13, 2010 | Washing Machines
My washing machine makes a loud noise when it spin dries. what could be the problem? it washes well; the machine does not shake or vibrate during the spin drying; it just makes a loud sound; it never was...
It sounds like the bearings are starting to go.The problem is as it is 6 years old the repair job could be expensive,unless you have an extended warranty.It still might be worth getting a quote off one of your local repair dealerships.
Hope this helps.
May 03, 2010 | AEG Lavamat W1050 Front Load Washer
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load washer loud noise and drum loose but not dropped
Spider arms attached to stainless steel drum inside of tub have probably broken. This is a known problem with Frigidaire front loading washing machines. The stainless steel drum has a 25 year warranty but this does not include the spider arms. You cannot buy the spider arms separately, you have to buy the unit as one. The drum cost about $250.00 and probably about $300.00 in labor to install. You can do it yourself but it is pretty involved. Good Luck!
Jan 02, 2009 | Frigidaire GLTR1670A Front Load Washer
Washer not spinning or draining. Making LOUD grinding noise.
i started a load it aggetates but when it gets to next cycle it does nothing . i can hear timer switch to next cycle but it doesnt soin or drain .what can it be?
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Boom and Bang Washing Machine
Bed sheets or comforters will often get out of balance in the spin cycle or during the rinse cycle. Throw some towels in there next time at least 5 big ones. They are engineered to take a little of this banging, it should only happen once in a while.
Oct 05, 2007 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
201 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
