Question about Sanyo DS27930 27" TV
Dark my tv is kind of dark i can still see everythin but nothing work i put all the settlin on high and still nothing
  • Kathy5508 Mar 19, 2008
    I have the same problem, my screen is also going dark. I think my tv is only 2-3 years old. Hope you can help me figure out how to fix it.
  • 25 Answers
Getting old
Posted on Dec 14, 2007
Hi, we have a ps3 we play Black Ops on. Its connected to a Sony Trinitron tv w/composite cables. Lately, the picture has been very hazy and dark, no bright colors like it used to be. Its hard to see where...
green sounds like a TV problem if persists with other games could be TV but im kinda thinking it is ingame settings occasionally updates can reset picture settings in the game i think for black ops it had some kind of adjust brightness until you can't see this object in background and sometimes it helps to go back and check that only other explanation would be you went to different resolution ex: 480, 720(hi def), 1080(highest high def)
Jan 15, 2011 | Sony Playstation 3 (PS3) Console
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
No main menu on PS2
Dear Customer,
This might be due to the over usage of the reading lense without cleaning.so i request u to open the console.you would see another cover covering the lense.open tat too.with the help of tissue just try to wipe out the lense n jus turn on the ps2 without closing anythin to jus check whether everythin is workin..if the dvd works,then arrange back or put back everythin back to it's position..hope this would work...else try calling a service engineer.
please rate this solution if it meets ur needs else choose fixya.Thank you...
Dec 16, 2008 | Sony PlayStation 2 (PS2) Console
Dark picture
you know it sounds like the same problem i had....
look this is something you can try.... "turn the tv off and unplugg it!!!"...you'll need to take out the lower front part of the tv......(where the speakers are to be exact) on each lower end you will find 2 screws..Be careful it will open to the side and there are many wires, i suggest you mark them to know where to put them back...then right in the middle there will be a black cover with about 5 screws..take them out....and look at the very bottom you'll see a thing with 6 pegs....the top ones are for the screen "DO NOT TOUCH THEM"...the ones on the bottom are for the colors...re adjust them...the left one it's for blue, the middle one it's for green and the last one it's for red...
I had the same problem after i moved....and after i re adjust that the tv looks super...
i hope that helps..:P
Sep 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Dark LCD screen
Have you tried using a manual aperture setting? Also try the back light function.
Jun 30, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Sony play station 1
Im guessing your using and antenna plug.
make sure your TV is on channel 3,4 or Video/Game channel.
If that doesn't work, reply.
Feb 26, 2008 | Video Game Consoles & Games
Dark Picture
The procedure for correcting dark picture is EXTREMELY dangerous.. If you're not sure about what you're doing call a qualified technician or you could seriously hurt yourself or get killed!
Picture Dark, abnormal, Changing Color Temperature
  • Clean the Spark Gaps on each CRT PWB. Remove the Cap, clean the contacts with thin fine sand paper, blow out, reseal.
  • Remove the CRT Sockets, clean the pins on the CRT. Push the CRT socket on and off several times.
Make really sure before you sttart this process that the Tv has been unplugged for several hours and that you discharge the crt as you remove the anode. There is some extremely high voltage present for hours after the Tv has been off...
Or get a reputable shop to come out and do the procedure for you - - might just save picking yourself up of the opposite wall.
Bill
Nov 20, 2007 | Hitachi 51F500 51" Rear Projection...
Power light comes on, followed by a high pitched whine
Hi, If after trying the TV again later and problem persist, repairs are in order. A high pitched whine is an indication of a fault at the horizontal section of your TV. The horizontal provides the high voltage for the picture tube. Your best bet maybe to seek the services of a qualified professional TV repairman since this involves component level repair, soldering/desoldering, use of soldering iron and VOM (testers) and knowledge of circuitry. Good luck and kind regards.
Aug 20, 2007 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Dark Picture
I'm not sure how to help you with this one as the unit you describe does not match the one listed in the thread. You talk about a WTV1903 TV but a Sony KV-27S42 is listed. One thing is for sure no matter which model you have you should never exceed the manufacturers rating for the fuse (which is not meantioned). You stated that a 4 amp fuse (12V) blew so you put in a 5 amp. You never raise the fuse rating. Larger means more current draw and the possibility of a fire. First put the correct size fuse in. It should be listed on the circuit board or in your literature. If the picture is dark either the CRT is bad or the High Voltage or screen drive is low or both. The fact that it is blowing fuses indicates that something is not working properly. You need to check the CRT with a tester. If good, check the High Voltage for the correct value. If this is good you could have a partially shorted flyback. If you are not qualified to work on these circuits, (they are dangerous) have a qualified tech do it. Good luck and don't put larger fuses in in the future!
Jun 25, 2006 | Sony KV-27S42 27" TV
Sanyo DS27930 27" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
