Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi VS-5041 (TV turns on but no pic or sound)
I have a Mitsubishi VS-5041 projection tv. Everytime I turn the tv on, there is a click sound, but the light next to the power button does not illuminate. I tried plugging the power cord in various outlets, tried different inputs, tried adjusting the volume but there is still no picture or sound. Please help!!! I have the same exact problem with my television. The tech that had answered the question previously mentioned that the problem could be 2 different issues, but only mentions 1. What is the other problem the tv could have? Let's say that problem is the power regulator...how could I go about replacing it....although dangerous....if I wanted to? Please Help
  • 2 more comments
  • therickerz Dec 14, 2007
    No..I don't get any lights. When I hit the power button all the tv does is make a clicking sound like it's going to turn on,but it doesn't....the little light that's suppose to turn on, on the power button doesn't. No sound either. I have a feeling it has to do with some sort of switch to kick the tv over...or maybe the power source doesn't have enough juice...I don't know...what do you think?
    Please Help...Thanks.
    Gianna
  • Anonymous Dec 15, 2007
    I have the "exact" same problem that therickerz's describes in his post for my Mitsubishi VS-5041. Prior to it going out for the last time, the picture and sound would go out while watching. Shutting it off and turning it on after a few hours or the next day, it would come back on. lt did this about a dozen times over the last two months before finally shutting down. Now when I try to turn it on or off all I hear is a clicking sound and no green power "on" light next to the power button. A similar post for the same problem/modle no. on another site suggests it may be the power supply board. Any suggestions on how to troubleshoot or cost to repair, would be greatly appreciated.
  • bpodell Jun 21, 2008
    Have a VS-5041 Mits I bought in 1995. It was working fine, turned it off one day and tried to turn it back on about 30 mins later. All I heard was a clicking sound. The power light no longer illuminates. No sound, no picture.
  • Anonymous Aug 15, 2008
    After moving the tv to another part of the room, it worked for maybe a day. then while watching a program it went out, picture and sound, only the faint clicking of a small relay inside when turned on. I checked (7) different fuses inside but all were o.k.. I was actually looking for some magic reset button but found none. No answer yet on a fix.
    President:
  • 4,402 Answers
Do you get a blinking red or green light?>
Posted on Dec 14, 2007
  • Cary Farah
    Cary Farah Dec 14, 2007
    well my guess is it's protection mode, have you tried to unplug the set?
    my next guess would be convergance ic or horz output transistor
    it really hard with out troubleshooting.
    if you have the skill to fix it yourself you can try this
    http://home.earthlink.net/~oleg.filippov...
Mitsubishi VS-5041
your set is not a DLP its a traditional rear projection tv set and has three picture tubes
there is not a bulb or color wheel in this model
if its dead ? you would need to check the power supply first to see if you have the proper voltages . the trouble shoot the rest of the circuits to see what is shutting it down . convergence circuit failure is always a good suspect in these sets
May 22, 2014 | Mitsubishi VS-50605 50" Rear Projection...
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs-5041 -after a few hours on, the tv goes black
Get the projection bulb checked if fine its something internal in your tv but i think you need new bulb
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Res.Burn
call the manufacturer
give them the name of tv and the model number of the tv
give them the location number r2200
you can order it
Feb 01, 2009 | Televison & Video
Mitusbishi vs 5041
Good Day, rob;
More than likely you have CRT coolant (fuild) on the board(s). Check this by removing the TV's speaker grill, the small panel and look for the fluid using a bright light. It's not always easy to see, if fluid is found remove it with acetone and use heavy plastic and drape loosely over the board in the front. Always remove POWER from TV BEFORE ATTEMPTING ANY SERVICE. Good Luck, big IRISH.
Aug 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
My TV won't turn on...
check the power supply sounds like its going out
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Remote for tv in closed cabinet
i don't know about the dip switch, but the ir receiver board in this mitsu is located in front of the mirror behind the screens
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No pic but have sound
CHECK C268 (22 UFD 50 V) OFF C OF Q215 V-PROTECTOR ON THE SIGNAL PCB
Mar 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Jun 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
378 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
