Tv will not turn on
Worked just fine note befor nwxt day went to turn on tv light came on then off will not come back on
  • 25 Answers
It's broken
Posted on Dec 14, 2007
Toshiba REGZA 40E200U 40 LCD TV wont turn on after it was working fine the night before.
Your TV needs servicing, Most likely you have a power supply related issue. Do you have any experience with electronics repair?
Sep 01, 2012 | Toshiba REGZA 40E200U 40" LCD TV
Tv just went off in use. Power light blinking, will no turn back on
Set is in shutdown as a short somewhere.
If model indicated here is correct someone has to open it and check voltages in power supply first.
Apr 01, 2012 | Toshiba 36AF43 36" TV
I have a mitsubishi ws-65313 projection tv i was waching it and went black now its not working the green light is on but tv isnt working and i try to turn it off and the ligth still on i push the botton...
Hi. i believe this to be either of these three problems.
1. Power: it could be that there is a problem with the power electronic element(s). the solution is to go see an engineer.
2. Screen: if the television uses LCD display, it could be a problem with the liquid in it. Solution is to see an engineer.
3. Sleep mode: the TV could be in sleep mode which makes the screen go blank until removed from sleep mode. Solution is to read the TV's users manual to see how to wake a sleeping TV. Get back.
Jul 15, 2011 | Mitsubishi Televison & Video
I have 1998 Chevy Silverado with over 200,000 miles. One morning I started it up just fine, backed out of the drive way, and it just died. I turned the ignition to off, and turned it back on and parked it....
Check your battery terminals. They may be corroded or just loose. If you get it running again have the battery and charger tested at an Advance or Autozone.
Hope this helps.
Rich
Aug 19, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Vizio GV47L not turning on after a pop noise
check your power board, most likely that's the part that is causing the problem.
Feb 09, 2009 | Vizio GV47LF Television
Power light blinking continuosly
First off check your lamp or replace it. You can never have too many lamps..........in the last minutes of overtime ! Are you kidding Me! If lamp doesn't work, you will need to find qualified servicer. Try craigslist or tv repair in yellowbook
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 70VS810 70" Rear Projection HDTV
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
The lights on but no-one's home - no picture on TV
Sounds like you have a short somewhere, probably the Horizontal Output Transistor. If there is a fault the led you mentioned probably should be blinking. You probably are going to need a tech to look at this as it is a very complicated process of elimination.
Jun 19, 2006 | Hitachi 46W500 46 in. TV/DVD Combo
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
