The washer works fine except the final spin cycle won't stop. Does this in both Normal and Permanent Press mode. I can manually stop it by pushing in the control button though.
Assuming that this is a basic top load, direct drive, neutral drain washer it seems as if the problem is likely in the timer.
The transmission and draining are controlled by the motor which gets it's power through the timer. If the timer isn't advancing once it gets to the spin cycle area, the motor keeps getting power, the machine keeps spinning and only by pushing in the control knob will the motor stop.
Here are a couple of places to look at how the machine works and parts for a basic Kenmore washer.
Does not pump out sudds and wash have machine Part No. 8280539 white & FSP # 8280541 Looks...
(More)
Does not pump out sudds and wash have machine Part No. 8280539 white & FSP # 8280541 Looks like I need motor drive control card with Part # 6021240103 , cap may be good like to change it part # Herovox w3
...and the is now an electrical odor as if the motor is being strained...we just bought a set and...
(More)
...and the is now an electrical odor as if the motor is being strained...we just bought a set and want to avoid being any more ripped....help!!
i just finished replacing the belt but i need to replaced the oil that leaked when i was replacing...
(More)
i just finished replacing the belt but i need to replaced the oil that leaked when i was replacing the belt .how do you add oil to the washer motor .
