Question about Dual Maxus 5.8GHz Handset Cordless Phone
Maxus dual phone 5.8gb radio shack cat43-3585
How do you get the ringer on????
Press the volume up key labellled as VOL/RING in standby mode to select one of five ringer tone and volume combinations...or Ringer Off.
Posted on Jul 30, 2008
We have no ringing tone
Look on the phone and the base. Most phones have a small almost hidden switch to turn off the ringer. It is usually a tiny slide switch on the side or back of the handset but I have seen them on the base also.
Apr 20, 2014 | Radio Shack Lands Phones
Owner manual
Its a dual trunking scanner which usually means either Uniden or Radio Shack.
Radio Shack has an area on their site where you can download manuals for almost all of their scanners and Uniden may have that as well online.
Bearcat is Uniden by the way who actually makes the Radio Shack units. On Radio Shack you may find a manual similar to the model if a Uniden unit.
Also if you have not tried it GOOGLE the brand and model number with "manual".
Dec 07, 2012 | Radio Communications
I have 2 Maxus 5.8 GHZ dual handsets, one began buzzing when answering a call. Removed battery and unplugged and the same thing occurred, It then when dead with no dial tone. I unplugged it to move the...
Try reset your wireless phones, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this process will help reset the phone and help fix all abnormalities.
Jun 25, 2011 | Dual Maxus 5.8GHz Handset Cordless Phone
I have a presidian corded phone for which I have lost the manual. I am unable to increase the ringer volume and hence can't hear the phone when it rings. I was in a radio shack store and they had a...
On the Presidian DECT 6.0, there is a screen near the top, with a ring centered beneath. If you press on the top or bottom of the ring, you will make the phone ringer louder or quieter. The display will also show you a volume bar as you make this selection. When you are done, press the button in the center of the ring.
Dec 11, 2009 | Lands Phones
No dial tone
Hmm.. Maybe it's because you shouldn't have two phones off the hook, Try puttinq one on and the other off and see if u get a dial tone.
Oct 04, 2009 | Dual Maxus 5.8GHz Handset Cordless Phone
Anwering calls
Press the delete/transfer button on the bottom of the phone and both ther phones will beep than the other one can be picked up with out being cut off.
Mar 05, 2009 | Dual Maxus 5.8GHz Handset Cordless Phone
Need ringer turned back on .. radio shack 5.8GHz
Hit the up or down arrow keys several times. (either key will work) and the ringer will rotate through Ringer off - Ringer low - Ringer high... one set will be a steady ring, the other set will be a warble ring. This works on the phone made for RadioShack with 5.8 GHz on the front and Cat. No. 43-155 under the battery in the battery compartment.
Dec 09, 2008 | Radio Shack 433575 Cordless Phone
Ringer on Sony SPP-S2730
The main board in the base is bad, I was never able to pinpoint the bad component after changing a few circuit board parts.
I only saw this problem in the 2730.
The only fix I found while at the Sony Service Center was to replace the board.
Radio Shack sells a remote ringer.... You could hook that to the phone line and it would ring... Not the best fix but it would help... Even another phone in another room...
Sorry.... This problem frustrated me.... Wanted to find the fix... The board is expensive if avaliable....
AL
Mar 20, 2008 | Sony SPP-S2730 Cordless Phone
After the batteries have been fully chaged, thephones will still not work until the they have been registered to the base unit. Just put each phone in the charging cradle in the base unit for about 10 seconds. The indicator light will blink during the registration. If you are lucky, this may solve the problem.
Nov 23, 2007 | Dual Maxus 5.8GHz Handset Cordless Phone
Wired base unit
Try a simple thing, replace the phone cord that goes from the wall to the phone with a new one. That'll make sure you still have a good phone connection. Cords cheap.
You have a power transformer that plugs into the wall.  See if you can find a replacement at a surplus store or Radio Shack (a different store)  Take the old one with you so you can match the voltage/ampere and connector.  If its new it will work fine.  If its surplus, it's hit or miss.
If that does not work  or you don't want to bother buy as new phone.  With the constant upgrades you might find one with better features you'll like more.  Who knows.
Good luck
Oct 25, 2007 | Dual Maxus 5.8GHz Handset Cordless Phone
Lands Phones Logo
254 people viewed this question
Top Dual Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Dual Lands Phone Expert? Answer questions, earn points and help others
