Question about Electrolux ICON Designer E30SO75ESS Oven
Electrolux Icon Mystery issue
Hi - product is the Electrolux Icon - regular and convection double ovens.
I used the self clean feature on the upper oven for the first time. worked great. 3 days later the upper oven will not function. I select the Upper oven and the type of heat (say Bake) and teh temperature. It seems to work - the fan is going 0- but it is not heating. What should I check?
Lower oven seems to work ok.
  • 3 more comments
  • KatieNeb Dec 25, 2007
    Thanks for the info - found teh issue - its like the self cleaner got so hot it tripped a wire - took off the front - assured all the connections were sound and Presto - it works fine.
  • Anonymous Mar 28, 2014
    Bottom oven will not keep the rite temperature
    Temperature gets to warm
    Can't set temperature to warm
    Temperature gauge doesn't work
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
Upper oven problem,
The Keypad (membrane) switches seem to be malfunctioning, this is very common on ovens these days especially if the unit has been self cleaned often. If you replace the membrane switch the unit should have all its functions again.
Dec 23, 2007 | GE Profile JTP56 Electric Double Oven
Tried to clean single Electrolux wall oven. The cycle began, the door locked and then the oven shut down with the door locked. I shut off the breaker for 10 minutes and then back on, no change. I checked...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 20, 2011 | Electrolux ICON 30 in. Double Wall Oven
How do set the self cleaning option on the Electrolux icon oven
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 05, 2011 | Electrolux Ovens
After light cleaning-Electrolux Ew30ES65 upper oven won't heat now! The bottom oven works fine, the lights are all on, the convection fan works in the upper over but the heating elements don't heat now....
I had the same issue with my EW30EW55GS. This is the second time! The dirst time, the technician replaced all the circuit boards (took a month to get the parts). I figured, I would try a light cleaning again. SAME THING! Again, I'm without an oven for no telling how long. The oven looks great, but don't be fooled - it's a piece of junk!
Apr 04, 2010 | Electrolux ICON Designer E30SO75ESS Oven
Kitchenaid double digital convection conversion oven keypad went out. Any ideas on the problem. Electric panel circuit breakers are okay. Sharon C.
I think these use the same controller board as the Jenn-air units, they have a weak capacitor (C3) on the control board (Timer/control Display). Remove the top panel and look for a discolored or leaking capacitor (usually black about 1/2" high 3/8" in accross). Replace the capacitor and the problem goes away, until next time you use the self clean cycle which seems to overheat the control board and ruin the capacitor.
Sep 23, 2009 | Electrolux 30" Built-In Double Electric...
Uneven rising & baking in convection oven
I repair commercial cooking equipment for a living. When a customer complains about uneven cooking the #1 thing that these manufacturers ask is..... are they turning (180*) the baking sheets half way thru the cook cycle. #2 are they staggering the pans front to back & side to side. It's kind of a pain but, works for the commercial ones.
Jul 24, 2009 | Amana AEW3530DD Electric Single Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Electrolux ICON  Designer E30SO75ESS Oven Logo
480 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
