Question about Dryers
Washer not draining right
On the last spin it seems that the washer is not spining and the clothes are not dry enough
  • Moee Dec 14, 2007
    model no. is 110.2970092
    the age is around 3 years
  • 126 Answers
Need age and model no.
Posted on Dec 14, 2007
  • john fraser Dec 15, 2007
    it could be your drive coupler. look under washer and see if there is black dust on the .if there is replace coupler.
Doesn't dry clothes in spin cycle- spins but not enough
so it is the spin cycle that does not work that is the drum does not turn. Have you tried other levels such as delicate wash and see if spin works. LASTLY, disconnect power and reconnect.
Mar 03, 2014 | Frigidaire ATF6000ES Front Load Washer
Clothes don't spin dry enough
you mean to say the clothes are tangled with each other tightly right?
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water not spining out
CLOTHES ARE SOAKED BECAUSE YOUR WASHER IS NOT DRAINING THE WATER.....ONCE YOUR MACHINE HAS DRAINED ENOUGH WATER OUT IT SHOULD START SPINNING AGAIN
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Hotpoint washer that is not spining clothes dry
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 01, 2011 | Hotpoint Washing Machines
Machne not spining fast enough to dry clothes, clothes still very wet after spin cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 19, 2011 | Washing Machines
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
Spins fine, but clothes still soaking wet
Clogged water pump. Not draing fast enough. If this is helpful, please post as such.
Feb 21, 2009 | Maytag Performa PAV2200
Washer won't spin clothes dry enough
Dear Langley,
please do the following checks.
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
please rate this solution.Thank You Langley
Dec 16, 2008 | Kenmore 15944 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
57 people viewed this question
Top Dryers Experts
Marvin
Marvin
