Question about Brother HL 1440 Laser Printer
Color too light
I just changed a new toner but the printouts are very light, why?
  • BECKY O Jan 11, 2008
    I also have the problem of my printer being to light. I have changed the toner and it is a name brand toner. I have cleaned the scanner and the printer and it is still printing real light. It was printing fine until the toner ran out.
  • Brother Master
  • 1,113 Answers
Non genuine toner usually is cause, but there area few others but in the majority(90%) of cases people reporting this problem have be found to be using aftermarket toners.
Please mark as fixya or reply to dig deeper.
Posted on Dec 30, 2007
I just purchased a Samsung Multi function color laser CLX-3175FW printer. It prints very light graphics. Eventhough I've set it to print graphics to the best setting, this doesn't help. The...
if you installate the printer you will find the Samsung (Blue) Logo with one watch in your taskbar on the bottem of your screen, double click on this icon, in the new windo click on Printer Setting then on color now you see an buttom "Color Adjustment" click on it, in the new window you can adjust your color via a slitswich for each color, try how you like your printout best.
May 10, 2011 | Samsung CLX-3175FW Multifunction Laser...
I have a hp color lj2600 that is creating double image on printouts. but if i printout a cleaning page it begins to reduce the double imaging. can the fuser cause this type of problem?
It may be the fuser, but if it is really it, then you should be able to notice some spots/lines that are there all the time, no matter what you print. I'd go for a magnetized corona, that fails to demagnetize the transfer roller.
Open up the printer, get to the print assembly and try demagnetizing the transfer corona (there should be a plastic bezel that slides along the rollers), or if nothing else then get some aluminum foil wrap it alongside the roller and touch the foil onto a metal part of the printer, to get it to ground the electric potential buildup.
Or it could also be the brushes that scrub the transfer roller clean from the residue toner. See if the excess toner tank is full. If it is full then it's the corona. If it's not full and you can see toner dust all over the printer then it's the brushes that fail to scrub off the toner in time.
Either case, you may be looking at a new print assembly purchase real soon.
Jan 17, 2011 | HP Color LaserJet 2600n Printer
My printout is "missing" a couple of columns as
it is toner problem just change it better if you install new toner.
Hope this helps. Please rate my response.
Have a good day
Dec 24, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Red light is flashing next to the triangle on my HP2600n laserjet. Do I have to replace all print cartridges that printer says are low
You only need to replace the light indicated toner cartridge but if the others are reading low be prepared to change them. You can do a supplies page printout from the printer menu, click on information and scroll down, this will tell you how much toner you have left in each cartridge
Jun 17, 2010 | HP Color LaserJet 2600n Printer
No hint of toner shortage but printouts lack color
Can be short of toner before the pagecount is at max for the capacity of cartridge.
If you look at the roller at the edge of the toner cartridge, it should have an even coating of fairly dense toner.
Remove each toner in turn, shake, and reinstall. This will often give you a few more pages.
Rated capacity is a guide based on a 5% page coverage.
Some remanufacturers are a little 'economical' with the toner they put in their catridges.
Jan 20, 2010 | Samsung CLP-510 Laser Printer
How to change toner
hi friend,
How to Change a Toner Cartridge You may need to change a toner cartridge when:
  • Your printer tells you toner is out (low toner usually means you can print a few hundred more pages without a problem)
  • The pages coming out of the printer look faded or washed out
  • The pages have a repeating defect of some kind
Users are able to and expected to be able to change toner in black and white printers. (Color printers are more difficult so if you are unsure of how to change color toner call the helpdesk and we will assist you.)
  1. First thing you will need to know is what model of printer you have.
    This will be written on the printer somewhere, there are 2 names that you will likely find on the printer, one is our name for the printer (i.e. ucrit01) the other is the model name (i.e. HP LaserJet 5m). You will need the model name.
  2. Take the model name to the central stores.
    They will be able to tell you which replacement toner cartridge to use. (If there is a problem identifying which replacement to use call the helpdesk.)
  3. Give them your cost center number and they will let you have the replacement toner cartridge that you need.
  4. Take the new cartridge back to the printer and remove the new toner cartridge from the box.
  5. Power the printer off.
  6. Open the top cover on the printer.
  7. Remove the old toner by pulling up and away from the printer. (It should come out with only a small amount of force)
  8. Remove the new toner from its bag, remove the rip strip from the cartridge. This is a small tab on the side of the cartridge that is attached to a plastic film strip. If you do not remove this strip the printer will only print blank sheets. Take care to avoid getting the toner on you when you rip off the strip. Spilled toner is best cleaned up with a dry cloth. If you spill any toner on yourself you can wash it off with COLD water (no hot water as it can cause the toner to set).
  9. Place the new cartridge into the printer the same way the old unit came out (there may be arrows or other cues to help you align the cartridge correctly.)
    It should slide in with minimal force. If it does not slide in easily, make sure you have the cartridge aligned correctly and that you are using the correct cartridge (i.e. 4000 series cartridge is not compatible with the 4100 series printer, you must use 4100 series cartridge).
  10. Once you have the cartridge seated all they way in place, close the top cover.
  11. Power the printer back on.
  12. Print a few test pages
    • If the printouts look good:
      You are just about done, package the old toner cartridge in the box the new toner came in and give it to the mailroom. We get a credit for the old cartridges. Now you are finished.
    • If there is a problem with the test pages:
      Our cartridges are refurbished and sometimes the cartridges can be defective. If you see streaks, repeated defects, faded out pages or other defects that did not exist before you changed, toner it may be because of a problem with the toner cartridge.
      Try getting another new cartridge, installing that cartridge, and printing some test pages. If the printouts are clean, then the first cartridge is a defect, return it to the mailroom for credit.
      If both new toner cartridges seem to have problems call the computer helpdesk. There is likely something wrong with the printer.
Please Note: Toner cartridges are light sensitive if you are going to leave them out of the box or printer for more than a few minutes please cover them to prevent damage
hope this helps u
please rate me........................
thank u for using fixya
Nov 24, 2009 | Samsung ML 1610 Laser Printer
Red light on suggesting replacement of parts
get geniune toners and replace waste toner bin.
Jul 05, 2009 | Samsung CLP 300 Laser Printer
HP 4600 has magenta and cyan marks on back of printouts.
Jan 06, 2009 | HP LaserJet 4600dn Color Printer
Don't take Printout of PDF file from refilled toner
It is possible that from your PDF files, the printing preferences are not configure to print the right cartridge. Before you click the last OK to print from a PDF file, click on Preferences of the printer and see if there is a tab to set the right cartridge (color or black).
Nov 11, 2008 | HP Office Equipment & Supplies
Shadow On Printout
Here are the possibilities:
-drum blade is not cleaning well, take out toner look at the shiny cylinder ( drum) is there toner on it? change cartridge.
- transfer roller ( black roller on bottom of machine that comes in contact with drum) take lint free cloth and wipe may need to be changed,
Oct 11, 2007 | HP Color LaserJet 9500HDN Printer
Brother HL 1440 Laser Printer Logo
35 people viewed this question
James Cagle
James Cagle
Jim Keysor
