you will have to remove drain motor and inspect. Access is normally from the front. once the kick panel is removed and the metal panel as well .If you dont see a drain motor, then it uses the main wash motor to do the drainagev via a solonoid. . check and see if the main motor is not jambed . Often happens. Try and remove pipe connected to plastic motor housing. Once off you can use a spanner to rotate pump blade. If tight, continue to rotate untill it is free. Then reassemble and try.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thank you, I will try this and let you know if it was successful.
" - kevin_hughes
Items on the bottom rack are not being cleaned properly - this problem started about 2 weeks ago and...
(More)
Items on the bottom rack are not being cleaned properly - this problem started about 2 weeks ago and is continuing. Any help much appreciated.
Base plates, I have 3 black parts on a used Bosch dishwasher, 1 curved, one rubber part that slips...
(More)
Base plates, I have 3 black parts on a used Bosch dishwasher, 1 curved, one rubber part that slips into the curved part and one steel part, in what order do they go and how do I attach them.
build up of calcium clean your hoses check your lines they maybe blocked sound like a high pitch...
(More)
build up of calcium clean your hoses check your lines they maybe blocked sound like a high pitch squeak something is stopping it from getting water
My Bosch Logixx dishwasher makes a banging noise when it starts the cycle and again half way...
(More)
My Bosch Logixx dishwasher makes a banging noise when it starts the cycle and again half way through. If I flick the rotating spray arms (upper and lower) it will start up without the banging, what is the problem please?
