Question about LG Flatron 775FT 17" CRT Monitor
Drivers I needs drivers for LG Flatron 775FT
  • aamirhaq34 Sep 17, 2008
    I need drivers for LG Flatron 775FT CRT. Thnx
    Sergeant:
  • 263 Answers
Go to http://www.Lg.com support drivers you need to check for you model make serial and windows tipe if you can not get it from there you can go to http://www.driversguide.com fill out the registration and go to the LG monitor and look for your model serial and windows system
Posted on Dec 28, 2007
To samir2253122:
thank you!
that is a pretty link for me ;)
Posted on Oct 21, 2008
Hi
your mail was failed so I upload software driver for LG775FT .
http://www.savefile.com/files/1792014
Posted on Sep 17, 2008
If you have got the driver for LG 775FT monitor for windows 98 please sent it to me on jigneshnpd@rediffmail.com
thanks
Posted on Sep 16, 2008
LG Flatron 775FT jag behöver drivrutiner till denna skärm och dom ska passa till win 98.
MVH
Bengt
bengan.liss@bredband.net
Posted on Aug 07, 2008
4 Suggested Answers
SOURCE: LG Flatron 775FT monitor distortion
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
Posted on Jul 27, 2007
ginko
  • 19396 Answers
SOURCE: monitor light blinking
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
  • 1602 Answers
SOURCE: I need the elctronic layout of monitor lg flatron
TYPE THE FOLLOWING INFORMATION
WWW.MFG NAME.COM/SERVICE
WWW.SCHEMITICS LG FLATRON 775FT [WHITE] 17" CRT MONITOR
ENTER
LG FLATRON 775FT 17" CRT MONITOR SCHEMITICS
OR
LAYOUT
ENTER
Posted on May 12, 2009
Vga cable problem
Step 1:
vga cable 9 wirs corict conniction
Step 2:
i need schematic digram of vga cable of lg t730sh
Nov 26, 2012 | LG Flatron 775FT 17" CRT Monitor
Lg flatron w1943 flickering
Two things, First you need to replace all of the capacitors on the power supply board at the same time even if they do not show signs of failure because they have been under stress. Secondly, you need to use the correct ratings on the capacitors not just the mfd and voltage. Parts from Radio Shack and such will not work right and can cause additional damage to the power supply board. Here is a link to an article about getting the correct capacitors for LCD monitor repairs.
http://www.ccl-la.com/blog/index.php/capacitors/
I hope this helps,
BuddyMc
Sep 03, 2012 | LG Flatron 775FT 17" CRT Monitor
My LG Studioworks model CRT monitor is not showing color properly.
Try Checking All The Cords
If It Works Out Ok Then Go To Your Monitors Menu Or OSD And Select RGB Or Colour
Play Around With Those Settings And See If It Makes A Difference
Jul 28, 2009 | LG Flatron 775FT 17" CRT Monitor
Hello! I have a problem with my LG 775FT monitor. I have used it for about 6 months. Everything was fine, and now I have a problem with picture. Its not steady. The brigthness its OK, just the picture is...
There's an internal hardware problem in your monitor, possibly cold soldered or defective electronic part/s. please bring the unit to an authorized service center for proper diagnosis & repair of the unit. best regards
May 13, 2009 | LG Flatron 775FT 17" CRT Monitor
I need the elctronic layout of monitor lg flatron 775ft
ENTER
OR
LAYOUT
ENTER
May 12, 2009 | LG Flatron 775FT 17" CRT Monitor
Don't turn on
try to replace the horizontal output. dela cruz repair shop cdo phil.
Nov 22, 2008 | LG Flatron 775FT 17" CRT Monitor
No signal
can you please help me?
I want the software driver for LG775FT for windows98. can you please send me through e-mail?
my e-mail is ::
thanks
Aug 20, 2008 | LG Flatron 775FT 17" CRT Monitor
Lg flatron l1510s
Try hooking the monitor up to another computer to see if the symptom remains the same if it does you might be needing a new monitor
Nov 01, 2007 | LG Flatron 775FT 17" CRT Monitor
Jul 25, 2007 | LG Flatron 775FT 17" CRT Monitor
LG Flatron 775FT 17" CRT Monitor Logo
867 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
