Question about Nokia 1600 Cellular Phone
Missing Button My phone got wet and i had to take it apart to let it dry. But when I put it back together i lost the flip button. So i need a replacement flip button. I couldnt find one on the internet. And i dont have sprint service so i cant go through them.
    President:
  • 1,944 Answers
Check here to see if they have the part that you need. Good luck.
Posted on Dec 14, 2007
Alright so i kinda lost my walkman mp3 out in the lawn xD ( it was in my sister's pocket and it fell onto the lawn) my mom found it while she was cleaning the lawn and that was prob 4 days after i had...
This is happening because your player has shorted out. Take the unit apart as far as you are comfortable. Put all the parts into a baggy of dry rice for 2 days. After 2 days, put the player back together and test it again. What this will do is remove all the water from the phone, it will not however reset the water damage check. If that doesn't work you may have to contact the manufacture to see about repair.
May 10, 2011 | Sony Walkman NWZ-S616F MP3 Player
On my remote every time I turn tv on it goes off
Sounds like the power button on either the remote is not releasing when you take your finger off the button. Or the circuit board is starting to go bad on the remote. here is one thing you can do. you can take the remote apart carefully remembering how it goes back together and clean the shell and the pad only don't get the circuit board wet but if you do let it dry for a day before putting it back together (this is the way I do it.) or you can buy a universal remote to replace the old one.
Sep 26, 2010 | Philips TP2784C TV
My LG Neon got wet is now really messed up
I had the same problem and fixed it rather easily, the problem is that the componants are wet and need to be dried, if you send it away your warrenty will be flaud as it is wet and all they will do to fix it is pull it apart and put it in a drying machine so i advise you to wrap it in a towel and place it somewhere warm like a hot water cubboard or directly in the sun, it needs to completly dry. you could try wrapping it in a towel and use a hairdryer on a low setting to dry out the componants, remeber to stop and let it air evey now and then or you will get condensation on your screen, hope this helps
Dec 22, 2009 | LG Neon GT365 Cell Phone
I need to know how to put bissell proheat 2x back together
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghsgh
Aug 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Need to put Bissell 7901 back together
heatman101 h
Aug 05, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My blackberry pearl flip got wet
Sorry to tell you but the back light on your blackberry pearl probably burnt out. That is one of the most common issues with a wet phone.
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Checkout the guide I wrote for replacing the blackberry flip LCD displayscreen. There are also links to by the new pearl flip LCD screens2.gif
Blackberry Flip 8220 LCD screen Replacement Guide
May 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Env2 got wet, front keypad having problmes, "o.k" button doesn't work can I remove front cover, how??
This just happened to me last night. I FIXED IT!
The bottom half was working, the top keyboard was not working. The only button on the top that worked was the power key. Today, I got a screwdriver and took the whole entire thing apart. Start by removing the battery, then take out the 6 back screws. Gently pull the back apart - this will be tough, do it evenly around all sides instead of getting just one side and yanking or you might break it. two of the screws on the top are accessible readily, but the two near the hinge are only accessible once the back is apart. Take the front apart with these 4 screws. dry it out with a q-tip. There should be four more screws inside - take those apart and dry clean. Pull the face off and dry the large white plate that receives all the button action. I put it all back together and my buttons worked again. I didn't even feel like I did anything to fix it because it wasn't really wet inside, i think there was just a micro-dot of moisture on that white plate. I hope it works for you. I was so excited about mine that I got on here to tell others. But hey - I also prayed about it and God cares even about the little things!!!!! Now - I've got the battery out and am leaving it out for a couple of days just to make sure that its totally drive because any water in there could still damage the phone if there is a power source. GOOD LUCK!
Mar 09, 2009 | Verizon Communications enV2 Cellular Phone
Palm Centro AT&T got wet;
http://www.fixya.com/support/r3771170-phone_water_damage
Jan 24, 2009 | Palm Treo 500 Centro
Keypad
just open your keypad and clean it wid little spirt wet clothand use it after it dry
Mar 15, 2008 | Samsung SGH-E370 Cellular Phone
KEYPAD
their is nothing you can do unless you have the correct tools to take your phone appart i used to work for a phone repair company and usuall it is just the case of cleaning the pads behind the buttons they either get greasy or if you have used the phone in the rain it only takes one of the pads to get wet or greasy and none of the buttons will work but iff you do take the phone apart remember their is an order to undo the screws and an order to tighten them and they need to be torqed to the right pressure to stop the board from warping hope this helps but i sugest you take it in to be done as you could totally destroy the phone putting it back together after
Oct 29, 2007 | Motorola Mobility RAZR V3
Nokia 1600 Cellular Phone Logo
22 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
