Question about Brother DCP-7020 All-In-One Laser Printer
Dust on Drum message after installinng new Drum
Since I had been getting "Toner Low" messages when the display told me to "Replace the Drum." Fortunately, I had a new drum on hand. Therefore, I put a new toner cartridge in the drum housing and installed them.
I then got the "Dust on Drum" message. As instructed, I removed the assembly and "cleaned the toner wire," several times, without cancelling the "Dust on Drum" message. I then went to a back-up printer. For several days, I repeated the toner wire routine, without success. Thinking that the new toner cartridge might somehow cause the fault, I put the old one in, but no change.
I then put the OLD drum and new cartridge in, and the DCP7020 proceded to print the cue of stored documents. So I'm limping along with the "old" drum. (Copies look fine!) and keeping my fingers crossed.
Unfortunately, I've had the replacement drum long enough that I can't recall who the supplier was (I think it was Tiger Direct), so swapping with them is not an option.
Any suggestions?
Bob B
  • Brother Master
  • 1,113 Answers
Dust on drum refers to as you correctly stated the wire, it carries a electric charge that transfers the image. If the wire gets contaminated the electricity dont flow right so dust on drum is desplayed, you drum cart is faulty, they are not repairable items, go buy another then claim new/old one as faulty from them. Um aH.
Posted on Dec 19, 2007
Toner life
You need to reset your Brother printer to get rid of the message
Mar 26, 2008 | Brother IntelliFax-2820 Laser Fax
It says drum error but the cart and drum is replaced with new and still can't get past the drum error message.
Hi There!
What you can do to clear the Drum Error message is to clean the corona wire.
  • Open front cover of the machine and remove the drum & toner cartridge assembly.
  • Remove the toner from the drum and gently shake the toner cartridge from side to side put it on a piece of paper to avoid scattering the toner.
  • Theres a blue tab on the upper left side of the drum, slide it from left to right, right to left about 5-6 times don't forget to put the blue tab back to it's home position(where the arrow is).
  • Put the toner back into the drum make sure it will click into place.
  • Reinstall the drum and toner assembly back into the machine and close the front cover.
  • LCD should display the date & time.
If you continue to receive the message try resetting the drum counter by doing the following:
  • Open the front cover
  • Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO".
  • Press 1 to reset the drum count.
  • Close the front cover
Hope this helps!
Vikroks
Mar 23, 2011 | Brother IntelliFax-2820 Laser Fax
We have a Brother MFC-8840D It states that we need to clean the drum - how do we go about that? Turning the machine off and then on it now says that the toner is low. Are these two separate problems or...
t probably told you to clean the drum because it can't sense toner. I would deal with the toner issue first.
You have about 150 prints @ 7% coverage before it won't let you do anything.
Feb 07, 2011 | Brother Office Equipment & Supplies
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Jun 18, 2009 | Muratec F320 Plain Paper LED Fax
Showing drum error and replace toner low message all the time
Open the cartridge cover
push "option"
and push "00"
wait until the word "accept" then close the cover,
after that should be working perfectly.
May 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
"Dust on Drum" problem
try using canned air to clean the coruna chagre wire assy
Apr 16, 2008 | Brother IntelliFax-2820 Laser Fax
Brother DCP-7020 All-In-One Laser Printer Logo
525 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
