Colour red missing
Advent hd 722i model 780 fst monitor has red missing from the display.
  • tezukaprince Aug 29, 2008
    My monitor have a problem with red colour missing but when I hit with my hand on that monitor it work on a while. What is the problem and what should I do? Can you send me a schematic circuit for this monitor and show where is the problem. Send to this email (
    Compaq CV 7500 17" CRT Monitor
  • Anonymous Oct 25, 2008
    Compaq mv9500 does not show red
the problem with your monitor is the poor solder of the red drive transistor which is located at the crt socket of your monitor the white one with approximately 9 pins. try soldering all of the components in the crt socket board.
Posted on Dec 22, 2007
Advent tv displays green
If you are saying no red: The model indicated here Recoton Advent Advent Q1435A TV is a 14 inch set.
first it may be cheaper to replace than repair--That said if no red look to the small circuit board at end of picture tube (it plugs onto the tube).
It will have either individual output transistors or a single IC.
What (if only one color missing) I would look at is the bottom side which faces to the rear---a circle of solder connections--possible one is broken--there will be one for each red, green, and blue--not always easy to see but if any of the solder connections look cracked or even broken loose-----
Mar 28, 2012 | Recoton Advent Advent Q1435A TV
Advent 5401 I have 6 split screens on the display advent 5401 i format the HD I removed the HD and still have the 6 split screen i think bios need to update or reflash can i get the bios for this...
I think the 'split screen is actually your wallpaper
To find out if I'm right - if you right click the desktop - choose properties, then desktop.
On the right side of the window that opens - look at the middle button, it probably says Tile. click the arrow to the right and choose Center. Now click O.K.
Your wallpaper should now be one 'screen' probably with a coloured border around it.
Aug 02, 2010 | Computers & Internet
Red colour problem
Try it on other PC, also try new VGA cable, then post back. This model may be still under warranty.
Apr 08, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
hope u r a u r handling chip-level repairing of monitor, knowing itz hazardous n dangerous..
however, check thoroughly for dry soulderings..(esp. at the crt base)..[this chance is maximum]..
see if the base is loose or faulty..
yes, it can b the 'chroma ic'..but don't ignore the associated components..(esp around the base)..
check video amplifier n sub section..
the colour diodes, transistors n resistances at the base..
for better supervision contact ur system admin/vendor....
Nov 11, 2009 | ADI Corporation MicroScan 5P (White) 17"...
Is this TV digital ready
According to
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
Red colour missing
red colour if missing from mother board then you can fix it from graphics properties of your mothrboard driver
but red may also due to monitor,there should be black colour appeaqrs on screen instead of red.
to solve this you have to take your monitor from where you have purchased
if it is in warranty or gurantee then dont take to third party
the fault in monitor may be due to
fault in monitor cable
also check that cable is not loose
try to plug the cable on cpu again
another fault is inside the monitor
also try to on monitor using detaching monitor cable from cpu,message come on monitor ,if in that message red colour appear,then monitor gun is ok
and problem is in monitor due to desoldiring
if you know about soledring than you can fix this problem yourself only if you know otherwise take it to shop from where you sold it
Nov 22, 2008 | Intel D101GGC Motherboard
Color change
1. red colour on the screen , or redcolour missing. redpatchs on the screen. tell me.
(1). in case red colour on the screen red colour missing.change the vga male connector.
2. red patches on the screen external digosing use.
Oct 13, 2008 | HP Pavilion M703c 17 in.CRT Conventional...
No video display
It is the problem of video amp. ic plz chage it.If only red colour is miss then check red driver transistor and cable
Jan 12, 2008 | LG Studioworks 45 14" CRT Monitor
Computers & Internet Logo
515 people viewed this question
David Payne
David Payne
