Question about Dryers
Dryer too hot
I have a whirlpool estate dryer and it is getting very hot to the touch on the outside. any ideas?
  • judiet Apr 27, 2008
    I just moved into a different house, had to change out the plug on my dryer to a four prong plug.  Now it seems that the dryer is too hot to the touch on the top and definely on the back of the dryer.  What could be wrong?
  • sooner909 Sep 25, 2008
    my dryer gets hot just by plugging it in. Does not have to be turned on and gets too hot to touch and a glow emits from th back.
  • 625 Answers
One or more of the blower duct overloads are malfunctioning allowing your temperature to go way past the set point.
Posted on Dec 15, 2007
Whirlpool duet sport dryer stopped running after 20 minutes into a 40 minute cycle on hot.
Check for clogged vent. Vents will clog midway and if vented to the outside of a house, there is a plastic cover that usually gets covered with lint that gets wet and dries to a hard mask.
Feb 02, 2017 | Whirlpool Dryers
An average load in the dryer is taking about 90 minutes to dry, which I think is way too long. I've check the vent and it is clear and air flowing through. Although there is some warmth to the... is an attached layout of your machine.
Usually with your indications it is something with the blower fan. So hot ar is not sent from the heating elecment to the drum. BUT before you start ordering parts, check the simple things first. Check to make sure that the dryer vent to open from the machine to the outside. That would also restrict air flow and cause your indications.
Jun 20, 2011 | Estate EED4400WQ Dryer
Whirlpool Estate Eelctric Dryer Serial #MS1013289. Dryer wa working got really really hot, clothes were so hot I could not even touch them...then went to use again and it would not turn on at al. They...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
Jun 16, 2011 | Estate TEDS740JQ Electric Dryer
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
Apr 15, 2010 | Whirlpool Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly.
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
The dryer will get hot but the drum will not go around
More than likely, the belt is broken. Otherwise, the drum motor is shot. (That's not very likely though).
Apr 22, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
its either the heating element or the limit switches both of which you can install yourself
Feb 05, 2009 | Whirlpool LER5636P Electric Dryer
Dying to slow
hi thanks for the question .I would look at the venting .from the dryer to the outside most problems occur because of poor ventilation dismantle vent and clean thanks the appliance doc
Sep 26, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
819 people viewed this question
Top Dryers Experts
