Question about RCA D52W19 52" Rear Projection Television
TV flickers and clicks for 15 minutes after powerup,
The problem with the TV is that in Video 1 and 2 inputs the TV flickers rapidly with a clicking sound. When I power the TV on it flickers for 15 minutes or so, them calms down. However it will flicker again on certain channels etc. It seems if there is a blast of white on a channel this sends the TV into flicker, while watching movies etc an “explosion sequence” is a trigger for sure….. also if I power off the “Cable box” then cycle through the Inputs on the TV to get back to the Video 1 source, then power the “cable” back on it sometimes gets the picture back to normal, but not always.
  • RCA Master
  • 5,138 Answers
Replace tuner borads.
Posted on Mar 03, 2008
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
Where do I plug in headphones?
Looking at the specs for your TV, it does not appear to have the jack for earphones.
You will have to connect an audio receiver to your TV and use the reciever's jack.
  • HDMI ports qty4
  • PC interfaceVGA (HD-15)
  • Input/Output connections3 x HDMI (19 pin HDMI Type A) - Rear,
    1 x HDMI (19 pin HDMI Type A) - Side,
    2 x Component video input (RCA phono x 3) - Rear,
    1 x Composite video/audio input (RCA phono x 3) - Side,
    2 x USB (4 pin USB Type A) - Side,
    1 x Ethernet (RJ-45) - Rear,
    2 x Audio line-in (RCA phono x 2) - Rear,
    1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear
  • Video interfaceHDMI,
Jul 14, 2012 | Samsung PN50B650 50-Inch 1080p Plasma HDTV
I have a Sylvania LC320SLX that will not turn on. When I hit the power button, the power on light blinks about 15 times then goes back to standby. I disconnected the cable input and unplugged the power...
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 23, 2011 | Sylvania LC320SLX 32 in. LCD TV
How to hook up a dvd on a proscan ps32600 tv
This tv has 2 AV inputs at rear to connect dvd player or any other video source.
Plug RCA video cable in AV Input-1 at rear of tv and select Input-1 source in tv remote to get dvd player playback picture in tv.
Click HERE to download user manual free copy that has details about tv operations.
Hope these info will help you.
Nov 26, 2010 | Proscan PS32600 32" TV
I have a customer on the phone who has a olevia flat screen and can not locate an input for his cable wire. where are they located?
here are the only signal inputs located at the back of the tv.
1 x HDMI input ( 19 pin HDMI Type A )
2 x component video input ( RCA phono x 3 )
1 x VGA input ( 15 pin HD D-Sub (HD-15) )
Audio line-in ( RCA phono x 2 )
2 x S-Video input ( 4 pin mini-DIN )
2 x composite video/audio input ( RCA phono x 3 )
1 x headphones ( mini-phone stereo 3.5 mm )
1 x SPDIF output ( TOS Link )
1 x audio line-out ( RCA phono x 2 )
1 x subwoofer output ( RCA phono )
1 x serial
If you are looking for a coaxial cable input.. it is actually not available so you have to connect a converter from coax cable to RCA cable for you to connect it on your tv.
Jun 04, 2010 | Olevia 237T 37 in. LCD TV
Does this system have a optical input
Here are the list of connections on this system
• Audio inputs/outputs 2 analogue input sources,
1 analogue output connection
- TV : in
- VCR : in
- CDR : out
- Headphone : 3.5 mm
• Digital audio in/output : 2 digital output connection
(coax, optical)
• Video outputs : 3 output connections (1 S-Video)
- TV : out
- VCR : out
- Monitor : out
• Speaker Connections suitable for speakers ≥ 6 Ohm
- left, right, center : click-fit connection
- rear left, right : click-fit connection
• Miscellaneous connections
- TV center speakers pre-out : 1
- Subwoofer pre-out : 1
- AM antenna : loop type
- FM antenna : coax
please mark this fixya if it has answered your question.
Dec 14, 2009 | Philips LX3000D System
About 20 minutes into a cycle (I usually use a rapid wash cycle-P3) the machine makes a loud clicking and grinding noise that lasts for about 1 minute. Any ideas what this could be and how to remedy the...
Danby customer service told me that it was built into the machine. The machine would shut off for about 15 minutes after that loud noise occurs. Then would finish the cycle after that point? Got infants, buy one of these products! LOL
Jul 29, 2009 | Danby DDW497W 22 in. Countertop Dishwasher
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
RCA D52W19 52" Rear Projection Television Logo
531 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
