Asrock K7S41GX Motherboard
Problem for Asrock K7S41GX Motherboard
I just replaced the power
By superman8429 on Sep 21, 2009
I just replaced the power supply for my computer it's been without power for about a month the sound is not working I downloaded a drive and still nothing how can I fix this
Solution #1
posted on Sep 21, 2009
Not Rated)
PC Commando
Rank: Guru
Rating: 86%, 43 votes
When you play an audio file it does not tell you that it is not able to play because there is no sound device?
Ok then what you will need to do is Go to Control Panel Doubke click on Sounds and Audio Devices...Ensure there is no check mark in the Mute section
Go to the Audio tab and ensure that you have a Default Playback device if you do not try to select the one you installed from the drop down menu.
If this does not work then you will need to right click on My Computer click on Properties then select the Hardware tab then click on the Device Manager Button. From there you will need to look for the catagory called Sound Video and Game Controller to see if you sound card has been install properly if it has not been instsalled properly then you will see a ! or a ? where the device is. If you are able to provide the type of audio device I can find you the driver.
Was this helpful?
Yes
No
Popular Solutions for Asrock K7S41GX Motherboard
Questions and Unsolved Problems for Asrock K7S41GX Motherboard
Do you recommend Asrock K7S41GX Motherboard?
Answer
Answer
Will not Boot Dell XPS600 Pentium D Processer 830 with Dual Core @ 3.0GGHz, 800FSB Vista Ultimate... (More)
Answer
the power cable from the front panel to the pins on the mother board is off
Answer
come posso aggiornare il bios ?ho un processore sempron 300+ e una scheda asrock k7s41gx,se metto un... (More)
Answer
fica aparecendo uma tela com algumas especifica?§?µes da placa e trava, n?£o... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in , CO
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
