Question about Gigabyte GA-7N400 Pro2 Motherboard
Memory not recognized?
I understand that this board has 3gb ram maxe but i can not get it to recognize any more then 2 if the 4 sticks i have in mach i have adjusted and readjusted them in diff slots
    President:
  • 4,402 Answers
Take all ram out and put one in at a time to see if it reads each one of them.
Posted on Dec 14, 2007
Is 2GB DDR2 PC2-6400 800MHz compatible with ASUS P5GC-MX/1333 if not what is the fastest and correct Ram I can fit;
From ASUS Site:
https://www.asus.com/us/Motherboards/P5GCMX1333/specifications/
2 x DIMM, max. 4GB, DDR2 667/533 MHz, non-ECC, un-buffered memory
Dual channel memory architecture
**When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Apr 01, 2017 | ASUS Computers & Internet
W7 64 bit pro
These are the specs, but I don't see 64 Bits support. Hence it must be running 32 bit and Windows 32 Bit has a 3GB limitation. Furthermore, even if it did recognize it. Your applications must be written to utilize more RAM. For instance I have 16GB and never seen the usage go more 3GB.
http://www.asus.com/Motherboards/P5VD2X/#specifications
2 x DIMM, Max. 4 GB, DDR2 533/ Non-ECC,Un-buffered Memory
May 17, 2013 | ASUS P5VD2-X Motherboard
RAM Slot does not recognize more than 512MB ( 184 )
Consider updating your motherboard bios.
http://www.asrock.com/mb/download.asp?Model=K7VT2&o=BIOS
Also make sure that your memory is correct for this system:
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
Jun 26, 2010 | Asrock K7VT2 Motherboard
My asus m3n78-em motherboard does not boots with 6 gb ddr2(3 chips of 2 gb) ram it works properly with 4 gb ram(2 chips of 2 gb) i dont know what to do it used to work properly before but its not working...
This board has a dual channel memory. To function correctly both channels must be identical otherwise , as you can witness, it chokes. To put it simply you must put either 2 identical sticks of memory or 4 - it can't run on 3.
Jun 16, 2010 | Computers & Internet
I have an Acer Aspire 7540-1284 laptop that came with 3GB memory. The specs say expandable to 4GB but the manual says expandable to 8GB using soDimm modules. I can't find info anywhere to support...
it prolly has 2 ram slots, capable of holding a 4gig ram stick apiece- for a total of 8 gigs.
however, the largest ram stick they currently make is 2 gigs. your board can support 2x4gigs of ram (8 altogether), buit the most ram you can currently purchase is 2x2gigs (for 4 gigs altogether).
additionally, you have to have a 64 buit version of windows to regognize all 8 gigs if you had them.
a 32 bit version of windows will recognize no more than 4 gigs of ram.
May 22, 2010 | Computers & Internet
ASUS P5VD2-MX SE recognizes only up to 2500MB RAM
Actually you are doing better than you think, According to your MB specs it is only supposed to hold a max of 2GB (1GB per slot). The updated BIOS may be allowing for the additional 500MB.
If you would like to verify, here is a link to the manual for your MB:
P5VD2-MX SE Manual
See page viii.
Thanks for using Fixya.
Wayne
Sep 09, 2009 | ASUS P5VD2-MX SE Motherboard
Asrock p4s61, tried 1gb pc3200 to max memory to 3gb, won't boot.
you quote one of your memory sticks as being pc 2700 when earlier in your text you qoute pc3200.
Firstly pc 3200 is 400 mhz clock speed memory.Secondly, pc 2700 is 333mhz clock speed and you acnnot mix the two on the same board. Thirdly does your board support 3ghz anyway. If you are running a board at 400mhz, pc2700 memory will not run at 400mhz.
Solution, take out the pc 2700 memory and all will be well.
May 02, 2009 | Asrock P4S61 Motherboard
Sony Vaio computer not recognizing added RAM
First, do you have a 32-bit or 64-bit operating system. Unless you have the latter, you will only see 3GB maximum.
Second, did you look at the Sony specs (you didn't say what model you have)? Chances are your Sony maxes out at 2GB.
Apr 14, 2009 | Sony Computers & Internet
4GB memory not being recognized
To recognize more than 3.5GB RAM you must use a 64 bit operating system
ordinary 32 bit O/S only recognize max of 3.25 to 3.5GB ram
Oct 31, 2008 | ASUS A8N-SLI Premium Motherboard
Gigabyte GA-7N400 Pro2 Motherboard Logo
106 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
