Question about Olevia LT37HVS 37 in. LCD HDTV
LG 26LX1d not power on
Hi there;
I have a 26LX1D LCD TV that is not power on, push the on-off button but is not power on, no lights, leds, etc.
checked 5A 250V fuse, is ok, other than that, I got lost.
any help will be ver much appreciated.
Thanks
JP
    Scholar:
  • 102 Answers
JPUente:
Usually all the manufacturers offer about 1yr of warranty. If your TV is under warranty please contact LG., they will ask you Serial number and model etc and guide you to a place to take it for further checkup.
If not then a certified technician has to look at it.
Thanks
Posted on Dec 14, 2007
LG LCD 26LX1D power blinking red ,all capacitor on power board are ok
try replacing relay on power supply had this twice on lg and goodman lcd tvs
Nov 25, 2012 | LG 26LX1D 26 in. LCD HDTV
I have an lg 26lx1d tv, suddenly red light bottom of screen was gone and then wouldn't turn power on.
  • Jeramie 36 solutionsMar 23, 2011
Replace capacitors c520 and c126 to get your power working again.
Also make sure that you don't have a broken green 3 inch jumper wire broke that lies under the heat shield in the top right corner. The wire should be glued to the board for stability. It sometimes breaks loose and will cause the TV screen to stay off.
Aug 28, 2012 | LG 26LX1D 26 in. LCD HDTV
I have an LG26LX1D tv, when I plug in the power cord, the red light stays on, but the TV won't turn on can anyone help?
hi,
Can you check is there is any variation in the red light when you press the stand by button. If it there is variation then you have to check the power supply of the tv.If there is no variation in red light then the mother board is faulty. if you need any more assistance feel free to contact me through FixYa.
ok
Aug 07, 2011 | LG 26LX1D 26 in. LCD HDTV
How to initial The TV? Problem: Only one channel available when connect a cable right now.
Hello:
It sounds like you need to do a "channel scan". For the LG 26LX1D, you can follow these directions:
  1. Press the "MENU" button on your remote
  2. Use the Up and Down Arrows to select "SETUP"
  3. Press the ">" button
  4. Use the Up and Down Arrows to select "EZ Scan"
  5. Press the "ENTER" button
This will scan all available channels. You can edit the channels by choosing "Channel Edit" in the same menu.
Mar 06, 2011 | LG 26LX1D 26 in. LCD HDTV
How to fix continous red blinking lights
Ur power board supply is dead.Replaced the power supply well solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Feb 11, 2010 | LG 26LX1D 26 in. LCD HDTV
My television LG 26lx1d doesn't turn on. I heard a
Mine did the same thing. It just seems dead, and ot lights at all. I tried another good cord, but nothing. Did you find the answer?
Feb 01, 2010 | LG 26LX1D 26 in. LCD HDTV
LG 26lx1d tv will not turn on. Power supply is fine. Remote control is working. Also tried on/off button on tv and tv does not turn on. Red light blinking on front bottom of tv near remote receiver.
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Jan 24, 2010 | LG 26LX1D 26 in. LCD HDTV
LG 26LX1D won't turn on.
My LG 26LX1D is the UA Version.
The solution for my problem was unclogging the Small Fan by the Main Panel, on the opposite side of the TV as the Power Board.
This is My Story.
The TV I found at the dump seemed good, but would not turn on.
Two LED's showed up on the front panel of the Television. First, the Red LED (on, off), then the Green LED (ON), then the Red LED (blinked) while the Green was still on.
I removed the back panel and saw that there were NO SIGNS OF BAD CAPACITORS on the Power Board. I plugged in the TV once more to see what would happen.
I noticed that there was a SMALL FAN which did not move when I plugged the power source to the outlet. This Fan was CLOGGED WITH DIRT.
I unscrewed the Fan from it's place and set it on a dish to act as a buffer against the main board. I then proceeded to clean it with a Vacuum Cleaner and a small Flathead Screwdriver.
I now own a FUNCTIONING LG 26LX1D-UA, RESSURRECTED!
Dec 31, 2009 | LG 26LX1D 26 in. LCD HDTV
I need to buy Powerboard for 26" LG LCD Television 26LX1D
There u go .!!
http://cgi.ebay.com/LG-Electronics%2FZenith-6871TPT303B-PCB---POWER-BOARD_W0QQitemZ390119483627QQcmdZViewItemQQimsxZ20091117?IMSfp=TL091117189007r1099
This product works with the following models:
LG Electronics/Zenith 26LX1D
LG Electronics/Zenith 26LX1D-U
LG Electronics/Zenith 32LP1D-UA
LG Electronics/Zenith 32LX1D
LG Electronics/Zenith 32LX1DUA
LG Electronics/Zenith 32LX3DCS-UA
LG Electronics/Zenith 32LX3DC-UA
LG Electronics/Zenith 32LX4DCS-UB
Nov 24, 2009 | LG 26LX1D 26 in. LCD HDTV
LG l26lxd1 HDTV
Your power board has gone bad and is not supplying enough power to start up the inverters. The LED lighting at all shows that you do have standby power, but that is all. You will need to have the power board replaced. Hope this helps.
Jan 07, 2009 | LG 26LX1D 26 in. LCD HDTV
Olevia LT37HVS 37 in. LCD HDTV Logo
208 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
